Flick Tom a email at PPG. He owns the ex PPG demo GTR and says the box has been in the car for 7 years, 40,000 kms and no issues/freshen ups. That's the helical 1-4 dog set.
How much do you value lightening fast shifts? Don't forget, that particular gear set, the ratios are substantially taller than factory (1-3).
Do you mean the helical or straight cut has tall ratios? If anything the GTR needs shorter ratios
They both have taller ratios.
Assuming a 265/35x18 tyre and stock ratios and a rev limit of 8000 RPM the speeds are as follow
Stock
1st - 75
2nd - 120
3rd - 180
PPG Helical and straight cut dog
1st - 89
2nd - 143
3rd - 189
OS GIKEN
1st - 87
2nd - 138
3rd - 190
  • 1 month later...
  • 1 month later...
Quaife only make the first series bushed shifter, but that isn't any good in my opinion. You cannot really use the stock shifter as it breaks the plastic bush after selecting reverse a few times.
I am investigating weather or not the OS88 direct shifter will work, but I have my reservations as it is made for the forward-back two-way selection of the sequential and is probably too short for the 6 speed H-pattern.
Best bet would be to have one custom-made. I am getting one for mine custom-made soon...I can get two made if you like.
Alternatively, you could buy an Ikeya sequential shifter conversion...but they aren't cheap
Charlie, why not just buy the os88 shifter. There are two to choose from. A straight one or a bent one.
http://otomoto.mobile034.com/p/8548992/os-giken-os-88-direct-shifter-kit.html
The OS88 shifter won't have enough leverage to go across when selecting reverse (needs to be slightly longer).
I have an OS88 shifter that I will try to confirm this, but looking at it, it won't work. Selcting 1 - 6 is fine, it's the extra few mm needed to go across and up into reverse that is the issue. And the narrow reverse idler gear of the Trust box is prone to wearing out due to this (I just replaced mine due to this issue).
Plus, I would rather the rest of the OS88, not just the shifter :D
I just missed out on a slightly used complete option 2 kit at a top price the other week...pity the Yen is so much stronger these days.
Plus, OSG say 2 month wait but it is usually 4 months....and $$$ upfront
However, if there are a few together, it will apparently be quicker....
We know that, can't do anything about it.
I need to know if you're in with us or not that way I have a firm number to try and bargain with.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
