Who are you guys going through? I got my os88 through Jesse streeter. Cost me a little over 15k delivered to my door that's option 3 ratio, angled shifter and adjustable clutch fork. That's with no tax paid but. Say if I valued the gearbox under $1000. I did have to wait 5 months for the box to get made( out if stock apparently) and the 4 days shipping for japan. If that's any help
$15K sounds about right for an option OS88 box. Did you also get the OS88 cross member?
I would try Ben from Otomoto, he is awesome when ordering from OSG as he is the Aussie Distributor. If I reall , Fatz got a great deal for us earlier on in this thread. It all depends on the AUD-YEN rate.
I am out as I am already sorted, Paul ;)
Yeah...I just missed out on a complete bolt in kit with option two box that had a very low kms on it. But got my hands on another one through Jesse Streeter.
I couldn't wait 4 or 5 months.
It gives 40mm better ground clearance. Will confirm if it fits BNR34 as I have seen conflicting information about that: RHD says it's for all 3 models; OSGiken's website doesn't speciify; and Otomoto says it's for R32 and R33.
Let me know if you need one, Jim.
Paul, I already have a Direct Clutch billet twin plate, so just changing the plates to suit the 26 spline Holinger shaft of the OS88.
None of those sites have it in stock...it's all ex-OSG Japan.
Apparently, one of the companies that makes some of the smaller bits (such as the forks) for OSG went under so they can no longer supply it.
Try some other sites and you never know your luck :)
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
