Who are you guys going through? I got my os88 through Jesse streeter. Cost me a little over 15k delivered to my door that's option 3 ratio, angled shifter and adjustable clutch fork. That's with no tax paid but. Say if I valued the gearbox under $1000. I did have to wait 5 months for the box to get made( out if stock apparently) and the 4 days shipping for japan. If that's any help
$15K sounds about right for an option OS88 box. Did you also get the OS88 cross member?
I would try Ben from Otomoto, he is awesome when ordering from OSG as he is the Aussie Distributor. If I reall , Fatz got a great deal for us earlier on in this thread. It all depends on the AUD-YEN rate.
I am out as I am already sorted, Paul ;)
Yeah...I just missed out on a complete bolt in kit with option two box that had a very low kms on it. But got my hands on another one through Jesse Streeter.
I couldn't wait 4 or 5 months.
It gives 40mm better ground clearance. Will confirm if it fits BNR34 as I have seen conflicting information about that: RHD says it's for all 3 models; OSGiken's website doesn't speciify; and Otomoto says it's for R32 and R33.
Let me know if you need one, Jim.
Paul, I already have a Direct Clutch billet twin plate, so just changing the plates to suit the 26 spline Holinger shaft of the OS88.
None of those sites have it in stock...it's all ex-OSG Japan.
Apparently, one of the companies that makes some of the smaller bits (such as the forks) for OSG went under so they can no longer supply it.
Try some other sites and you never know your luck :)
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
