In Neutral you lift the reverse ring that sits under the shift knob on the shifter and push forward. Lift the ring and pull back to go back into Neutral.
  • Like 1
A few guys on the pommie forum have. One bloke by the name of Hugh Keir has an R34 GTR and the current setup is an OS 3.0 with twin HKS 3037's. He put the 88 in the car in 2007, pulled it out and put different ratios in it in 2009 and hasn't touched it since. It was a daily driver at one stage too.
How far off are you Paul?
Box was ordered 12 or 13 weeks ago on Thursday. OS say 2-3 months from payment till when the box is ready. Not sure is Christmas uaha slowed them down a week or two. I'd say it would be delivered to import monsters warehouse in japan within the two weeks then 1 month on a boat. Once it gets here it's full steam ahead.... Sooo 8 weeks or so?
  • 3 months later...
Who's using strain guages or shift cut knobs?
im looking at this one, any good?
Anyone using the holinger shift cut knob?
http://www.drenth-gearboxes.com/products/accessories/gearlever-strain_gauge.html
Edited by QUP29
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
    • These arrived today! Sadly I'm going to probably be smart and enjoy the car as is over the summer/sunny period and save the ~2 weeks downtime it'd take to swap the heads over and tune later in the year. Maybe. It's going to be pretty damn tempting seeing these bolt on funs just sitting in storage when they're ready to go. There's a non-zero chance I end up @The Bogan'ing it.
    • MZ11 Toyota Soarer in Iwata, Higashi Osaka
