Hey Guys.
I guess this is a EOI for this unit, i know there kinda hard to come accross that arent destroyed, this one works great, no marks on screen, touch prompt's are sharp and doesn't require hard or multiple presses like some used touch screen units. Comes with the standard remote control aswell.
I am not very familiar with this unit, its the first one ive come accross but from what i can gather it seems that there is another single din module that i am missing from the car so this is the double din controller part that you can put cd's into. It suits someone that has the other module and needs a replacement display.
I am not sure how much this is worth however i have seen on the net that Brand new Nissan replacements are 12K, obviously that's not what Im going for but throw me some intel and show me what there worth in our market.
Text me if you want some pics as i have them ready.
Cheers
Chris
04128one355one
    • Man, you guys are like an all knowing encyclopedia.. how do you guys know how to fix everything?? but thanks. i will try to trace this wiring today. What is this globe thing you are referring too? Globe Power Supply? Are you referring to the light bulb?
    • Vinyl paint always ends up coming off interior trim and looking like arse. For the a pillar trims.....just try cleaning them with fabric shampoo? Maybe ditto for the headliner.
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
