Hey guys,
Anyone know anywhere to get a decent carbonfiber bonnet for an R34 GTT?
I've had a JustJap one, the bonnet latch didn't reach even after adjusting the catch/release clip by making the bolt holes bigger and raising it up. Welded a longer latch on, still eventually blew up smashed my windshield and ofcourse destoryed the bonnet. Shit happens ;) Also once fitted you needed to remove the stock strutbar as the vents sit lower and bow the bonnet.
But I'm after a new one since my stock bonnet has a couple of holes in it from the previous owner. I've found a couple on Ebay, none of sellers have got back to me and I'm scared of fitment buying one off Ebay.
So any websites, or private sellers on here that people have used with no problems would be a great help.
Cheers, Zac
https://www.sau.com.au/forums/topic/434460-r34-carbonfiber-bonnet/
Not sure if the GT-R and GT-t bonnets are interchangeable. You might be able to find second hand on Yahoo, or perhaps you can buy them new. Try contacting Jesse Streeter.
Know where/how I can get in contact with him?
^ that actually looks pretty good, has what looks like the support structure on the underside.
There should be a few manufacturers still making ER34 bonnets (East Bear, maybe Top Secret?) or find someone who has them in stock. Sorry man I'm not much of a help, just trying to point you in the right directions.
Search for "jesse streeter" using your web search engine of choice.
GTR and GTT bonnets arent a direct swap. Need to swap over hood latch and hinge iirc. Plus you'd still have a gap between the headlights. For all that effort, might as well for a GTR front conversion.
Otherwise, GTR style hoods made for GTT is the way to go.
http://www.musecret.com.au/prod1321.htm
thats where I got the bonnet in my avatar. perfect fit, only had to modify the windscreen washer holes.
Did it fit without hitting the strutbar? That's the style I bought from JustJap and thats one of the problems I had with it
Thank you everyone for your help also!
dont forget to fit bonnet pins, i did mine with aerocatch flush ones for added security
Yeah I have a set off bonnet pins for justjap already, don't want to risk it again ;)
Thanks for all your help guys, awaiting a reply from seibon now for postage quotes :)
I've never seen plugs for them, Although I like the idea! I like taking the try off but it was always a pain when it rained because you have to screw it back on ;)
Just sticking plugs in the vents with the bonnet closed would be decent
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
