Hi Guys,
I purchased my skyline like this and i believe they scratched it installing the backyard japspec headunit that had i kid you not over 100 cables shoved in behind the head unit and carpet which was a nightmare to remove.
Do you guys have any pointers on restoring this? Or is it best to just find a replacement and swap it out.
Cheers,
Peter
Edited by petery3
https://www.sau.com.au/forums/topic/434488-restoring-interior-paint/
well its not paint its just plastic which is scratched.
easier to get a replacement but.
there are guys who can do plastic repairs, basically they heat it up and smooth it out then when its hot and plyable then press on a paterned material to match whats there and your done.
what would the most cost effective solution be? also what do you even call that part of the car? is it apart of the center console or?
here's a tip for you, most cost effective TEMPORARY - mid term solution = get some black shoe polish and a cloth, and buff it out. By buff it out obviously i don't mean it will buff out but the polish will fill in the scratches and it won't be very noticeable, to the point that if you don't pay attention you wont notice them there.
That of course depends on how deep those scratches are, though yours looks as bad as mine, so yeah it'll work.
This did the job for me :yes: .. though i didnt have many scratches to begin
  • 3 weeks later...
So what exactly is this replacement part called lol? It's not exactly a centre console or anything
It looks like the lower part of the dash, so apart of the dash pad. I would be looking for a complete dash in good condition.
I'm in the same boat as you but im also looking for a way to freshen up the plastic trims around the gear selector all the way up to the tripple gauges. They've gone all soft/mouldy sort of.
Anyone with ideas ?
The DIY section has a good write up on respraying the plastic trim with spray cans. could look into that. otherwise parts are always available just gotta look a bit :)
Bronson.
Edited by Bronno!
Anyone with ideas ?
sand back lightly, then respray. that's about it, apart from getting a custom dash getting made up. i know who can do that for you though.
Yeah I was thinking of doing that but I want to get it as close as possible to the rest of the dash .
It must be the aussie heat and the quality of the trims because it only happens around the gear selector trims and radio. The rest of the dash trims are perfect condition.
Was thinking of cleaning the trims and vinyl wrapping it but the trims seem very fiddly especially the corners and cigarette lighter
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
