Hey everyone,
Finally decided to create a thread asking why this is the case with my car.
The main point being - it's eating up a lot of petrol.
This is my first car which is turbo, and I realise GTT's consume more petrol then N/A's.
But the tank before I filled up, I only got 261km's out of almost a full tank.
From what I've heard, that's far less then average.
Any reason why this could be?
Seeing as this car is my baby, it's rarely driven let alone thrashed.
Cheers.
Edited by Swole
https://www.sau.com.au/forums/topic/434493-r34-gtt-chewing-up-petrol/
Lots of short trips......
Nope, drives usually go for as long as cruises (because they generally are cruises), probably between 1-3 hours.
Got told that the car may have been tuned to consume more petrol and if so I should get it retuned?
Several things come to mind,
Dirty afm
Faulty water temp sensor
O2 busted
Atmospheric bov
Intercooler leaks
Unsure of what half those mean but I'll definitely ask some mates.
Cheers.
Edited by Swole
a tune shouldn't make a car chew more fuel unless you are really relentlessly using the extra power that a tune has unleashed.
otherwise, that kind of fuel usage certainly points to an issue somewhere and the solution is bound to be in the list mentioned above.
take it to a reputable shop that knows skylines and get them to go thru the list testing the various components.
How much fuel did you put in to fill the tank?
Driving style is always a big contributor to fuel economy - good or bad. If you consistently use boost, you will get crap economy. Unless you can CRUISE - on a constant throttle - the O2 sensor will not play any significant role in getting good fuel economy. City driving, or any form of on/off throttle driving, is not conducive to getting the ECU to pay any attention to the O2 sensor. If you let the engine warm up before driving anywhere, then of course you will get crap economy - burning fuel to do no distance doesn't make sense.
No matter how hard you drive a stocky R34 it should not get that bad in terms of fuel economy which indicates there is a problem.... I have had my car tuned from semi stock all the way through to where it is now and it hasnt been that bad on fuel even on ethanol.... Take it to a reputable tuner or mechanic and get it sussed out as you certainly have a problem :)
45L before that tank, then 49L after using it.
Yep, already got a couple mates who are mechanics to check it out.
Thanks for the responses.
You're lucky, I get 180-200kms out of a full tank of V-Power and the only mods I have are a front mount, exhaust, 12psi boost on stock turbo, tuned to 215rwkw with a power fc, it's got a new 02 sensor, I cleaned out the AFM not long ago, new set of plugs, only thing I can think of is the exhaust leak I have at the moment but I don't think it should be that much.
  • Like 1
I was getting around 13.8-14.5L per 100km with my GTT, 12psi, exhaust, nistune. Changed o2 sensor, afm, fuel filter, spark plugs (1.1mm gap), all did nothing... Then I noticed the car idles a little rough, so I re-gapped my plugs to (0.9mm), clean AAC valve and reset the ECU, car idles a lot smoother and now can do about 12.5L per 100km and thats city driving.
Also if someone has put a low temp thermostat in, or yours is stuck open, then that will also add to poor fuel efficiency. Cold crank enrichment tapers off at 70C so the quicker she gets up to temp the better.
Edited by Missileman
It's been like that always, when it was stock and after the tune, I do do alot of short trips, I'm running PFR8 plugs with a 0.9 gapp, car idles smooth, but you can farken smell the richness when I come to a stop or idle.
I was thinking of cleaning the AAC valve would that do anything, is it the same process as the r33 tutorial write up? Would the exhaust leak be causing it aswell.
Yeah, basically the same, but you need to disconnect 2-3 coolant hose up the top, and you just need to quickly bleed the system after you put the AAC back together by loosening the bolt and start the car and then when coolant start coming up, tighten the bolt and your done. It looked/sounded difficult but it's very simple.
id both be changing you rthermostat and 02 sensor. 100 bucks. if it works great, if not, you have two new parts that you know are fine. 02 sensors are meant to be changed every 40k and most have the original factory one in.
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
