Can someone PLEASE tell me where this RB30 Come out of.
It's driving me insane, i was told it was a vl series 2 block, but i dont believe it is after ringing holden.
bought it off a shop and had it worked on.. they said it was great block rarraa.
Don't want to really mention the shopp at the present moment.
That aside , heres the number 045903a
Please help me if you can.
Thanks.
  • Like 1
Can't really see from the pics but are you worried about where the second idler needs to go (exhaust cam side)? It does look like you don't have the machined spot but there are ways around it.
ive been unlucky because my block had casting marks where the idler pulley goes.. usuallly thry are flat. i even asked anthony from dahtone and he said his never seen a block with them marks on it...
its always nice to know where thr block come from
Edited by sultanaz
So why didn't you take a photo of that area, and ask the question directly? Anyway, I guessed it! points to me. ... Like I said the are ways around it. seeing as engine is assembled machining it might be a little difficult but still an option, the other is to make a solid bracket to hold Idler or go nizpro style and use idler and tensioner above water pump. That would be the easiest but finding a correct belt would become the problem. Edited by superben
as it is a series one block I don't think you have a turbo oil feed plug there? I assume you could drill into the gallery and tap it but I wouldn't do that now as it's assembled. I would tee piece off oil pressure valve.
No such thing as a series 1 or 2 block.
The early non turbo blocks had no oil feed hole and water hole drilled and tapped in the block.
Later non turbo blocks did, like the original turbo blocks, this is what most people call a series 2 for some reason, Holden did many running changes during the production years to the blocks.
How you can tell yours is a later block (like mine) is by looking at the first picture, the hot side.
Between welsh plug 3 and 4 is a drilled and tapped hole a little below them, thats your oil feed and the 2 holes above one another after the last welsh plug on that side, if they are drilled and tapped, that's your water feed.
Early non turbo blocks were not drilled and threaded in those places, they just had a cast area where you could dill and tap them yourself, you needed to do this yourself, later blocks that everyone called series 2 blocks had these drilled and threaded from the factory.
Going by your pics they look drilled and threaded......if so its a later block that everyone calls a series 2 block.
Edited by GTRPSI
The other difference on the blocks is where the Idler bolts on. You want to use a block with the oil feed plugged ready to use and the Idler location machined and tapped. Perhaps people call it a series2 block as the series 2 vl probably has the changes on the block, so not so much the block is series 2 but that it come feom a series 2 car.
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
