Hey guys so just got the car tuned its making 450hp at the wheels only running an exedy heavy duty witch is starting to slip so in need or a new one my budged is around $700-1000
What would the best clutch for my application be that will get reasanilbe amount of time & use out of it? Street car with abit of track/drift on the weekends
Thanx
for your budget your likely going back to Exedy
TBH for that price you'll be getting a better clutch from NPC..
I've got a 10" modified Patrol Exedy pressure plate with their infamous carbotic plate for under ~$800 delivered... Doug from NPC said it will take up to 400kW any day of the week.
best part is, the pedal feels as soft as a stock clutch... I even thought I fked the clutch install when I when to test my pedal.
Ok awesome! What I don't get is why the carbotic is over $200 dollars difference if its a lot better then the Kevlar button?
These are the prices I got:
10" cushioned button :- $907.5
10" Kevlar button :- $973.50
10" carbotic button:- $753.5
maybe the material costs?
I've never used a kevlar clutch before so I can't comment.. but a ceramic vs. carbotic I must say the ceramic is easier to drive :)
It takes a man to drive a carbotic clutch, I'm pretty used to mine and can go through Sydney traffic without stalling it (when I'm alert, when I'm tired after work it's stall-o-matic)
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
