Hey guys so just got the car tuned its making 450hp at the wheels only running an exedy heavy duty witch is starting to slip so in need or a new one my budged is around $700-1000
What would the best clutch for my application be that will get reasanilbe amount of time & use out of it? Street car with abit of track/drift on the weekends
Thanx
for your budget your likely going back to Exedy
TBH for that price you'll be getting a better clutch from NPC..
I've got a 10" modified Patrol Exedy pressure plate with their infamous carbotic plate for under ~$800 delivered... Doug from NPC said it will take up to 400kW any day of the week.
best part is, the pedal feels as soft as a stock clutch... I even thought I fked the clutch install when I when to test my pedal.
Ok awesome! What I don't get is why the carbotic is over $200 dollars difference if its a lot better then the Kevlar button?
These are the prices I got:
10" cushioned button :- $907.5
10" Kevlar button :- $973.50
10" carbotic button:- $753.5
maybe the material costs?
I've never used a kevlar clutch before so I can't comment.. but a ceramic vs. carbotic I must say the ceramic is easier to drive :)
It takes a man to drive a carbotic clutch, I'm pretty used to mine and can go through Sydney traffic without stalling it (when I'm alert, when I'm tired after work it's stall-o-matic)
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
