May take you up on that Mitch. Base on the youtube vids I've seen and the documentation it looks pretty straight forward. I'm just making up the external map and wideband interface looms now.
I can't imagine Haltech would have left any surprises for me. Out of the box it should control the fuel pump speed and send the correct TPS signals to the Attessa right? Ive seen lots of other people have issues with these two simple things... Edit: Other ecu's of course... Wolf/vipec etc...
Edited by GTRNUR
High/low fuel pump control is hard set at 5% throttle opening (from memory). The TPS follower for the ATTESA 100% works as per factory, as does the injection duty signal to the MFD.
The pre-loaded base map should be enough for you to get started with. Just make sure you load the calibration for your MAP sensor, set your TPS limits, enter your injector characteristics and deadtimes and away you go. Set base timing (i like to lock the CAS all the way clockwise) by enabling the ignition lock and adjusting the trigger angle. Dont forget to set the engine capacity, and if you're running an ethanol blend of fuel without a flex sensor, deduct ~33% from your injection flow rate to allow for the fuel density difference. :cheers:
Not necessary, it just connects to Inj1. The MFD does the rest.
If you were able to program up an 7th injector channel, it would need to be configured to have the same output pulse width as all the other injectors. Also, you would need to put a load on the output, or a pull up resistor to +12v so the MFD would be able to read the variable PWM square wave.
Sorry no dyno time yet.
The Haltech is in now. It idles and revs. Didn't get a chance to drive it anywhere though, nor do anything but do the basic setup on the weekend.
With any luck I can take a day or two off later this week and spend some time on the phone with Mitch.
AI tell me my surge tank is still 2+ weeks away as well.
  • 2 months later...
More changes are still in the works. I've replaced the entire fuel system again after being talked into going down the E85 flex fuel path. So bigger injectors, more pumps, bigger fuel lines, external surge tank and bags of fittings...
It takes for ever to get parts up here too. Pay for overnight and it arrives 3+ days later.
I've yet to source and wire in a flex fuel sensor, and I've got locate a fuel cooler to mount behind the diff too.
The interesting news is that I hope to be getting Mercury Motorsports to come to Cairns to do the final tune and setup of the car. If anyone can get it to produce a good final result, I think they are certainly capable of it.
  • 1 month later...
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
