Rb34 / 24U (Rb26 + 800Cc) - Project RB high deck engine (and related builds)
Amazing results, credit to you and your research.
If you don't mind me asking, What is your daily job? Do the skills from that job help you at all in the design and build of this motor? Or is this solely an enthusiasts desire to get the best results possible?
I do computer/network management and programming for a living. For the past 10 years I have been primarily supporting engineering firms. From that I have had a lot of exposure to engineering principals, CAD systems and CNC. As well as engineering support from some very clever people.
Add to this that I have been building engines of various kinds since before I could hold a license.
I've decided to get a set of Supertech valve springs for this current engine to sort out the valve float issue, and hopefully punch through that 500kw atw limit. Then maybe also a switch to an EFR 9180 as well.
Truly epic thread here! So thorough and well thought out.
A pleasure to read it from start to finish. If/when you make this a "kit" I can only hope I'll be in a position to get a setup like this for my 33 GTR.
Keep up the great work.
  • 4 weeks later...
Thanks Dan.
Not much to report other than that I am going through E85 like no tomorrow. I must do a video of what the car drives like. There is a little maintenance to catch up on, needs a wheel alignment and balance, but other than that its still going strong.
Yes its still a stock getrag for the moment. Basically I'll drive it like this until next year some time when it will get an OS88. The drag strip is still being built, so I wont be breaking the getrag anytime soon.
The main focus is on the next two engines now, which will hopefully be finished around November.
  • Like 3
These next two engines are about stress testing the design. Both are being built with a 1000+hp power goal in mind. No expense spared, with a focus on maximum strength for all components.
Once testing has proved the design holds up for the first engine, the second will become available as the first to ever be sold.
  • 3 weeks later...
I am still in the process of getting the final parts made for the next two engines.
One of the two cylinder heads is ready to go. Ported, oversize valves, 280x11.5 cams, dual springs, the works. The second head is still being made, and in comparison it makes the first one look like stock. I am told it will flow past 1kw with ease.
Two crankshafts have been completed and are ready to install. One 87.8mm and one 89.8mm, both with 19mm GTiR journals and clearenced for oil squirters.
Two N1 24U Blocks are now partly composite resin filled, and are about to be sleeved and fitted with girdle plates and main caps. Then onto final bore/hone machining once the pistons arrive.
I am hopeful that I will be assembling engines early to mid December.
Edited by GTRNUR
  • Like 2
  • 1 month later...
I am still waiting on pistons for the next two engines. It took quite some time to get the specifications sorted out for something that will handle extreme punishment for an extended time. In the end I went with a custom JE and Trend DLC coated gudgeons. I'm told they will handle 1800hp+, with a specification normally found in a methanol engine.
I completed the rear R35 GTR brake conversion, and have a functional hand brake thanks to modified Toyota Rav 4 hand brake shoes.
Other than that I have been working on the front suspension lately. I've changed the lower control arms to R33 GTR items, so I can use adjustable tension rods. I've yet to locate or make a set of roll centre correction spacers. Upper arms will be fitted with superpro offset bushes to correct camber.
I've also done the first plug change and compression test since the tune. Dry test and every cylinder is within 3psi, which is amazing. The best leak down and pressure test result I've ever had. Then I re-pressure tested the entire intake side of the engine and found the reason I didn't break 500kw in the last tune session. At some stage between the first and second tune sessions, a weld had developed a small crack in a pipe that links the turbo to the intercooler. So essentially I made 610hp with a serious induction leak. I've had to turn off boost control now too, as it hit boost cut on the first drive once the leaks were fixed.
I believe the leak was in part due to a mostly torn through nismo engine mount, as there has been other signs the engine has moved a little too much. I was blowing off pipes during dyno tuning, but also, the plenum has made contact with the clutch master cylinder at some stage.
I changed my first front inner CV boot too. What a fun task that is.
That's all for now.
  • Like 1
  • 1 month later...
Update time!
Today truely a great day. With the boost issue fixed Trent from Mercury Motorsport was able to get the engine to perform as I had hoped, and we finally got the 500KW ATW goal.
We had a couple of minor issues with blowing off intercooler pipes again, but other than that the car performed flawlessly.
Huge thanks to Trent @ Mercury Motorsports and Daniel Stephensen from LK motors for performing all the tuning and dyno setup.
526kw atw at 28psi (pipe blew off in this run).
495kw atw at 26psi
33 degrees, 82% Humidity! Stinking hot!
I never saw hotter than 86 degrees on the MFD, (Oil and Water)! My cooling sytem rocks!
Edited by GTRNUR
  • Like 2
    • It depends on what the guy who bought its Ratio is. Mine is a 4.36 Jus Jap told me anything above a 3:9 has equal length shafts which the Nismo center's shafts were not.
    • If those shafts in the last 2 photos are the ones that came with the diff, you have no hope of fitting the other ones because they are completely different
    • I have recently fitted a Nismo GT Pro Center second Hand buy still in the box i got stubs with it but they are 5 bolt and I need 6 (3x2) I was told by Just Jap that for a 4:36 ratio the stub axles are equal length sku 38220-0V161. They didn't have any in stock but I picked up the ones pictured. The one with 5 bolt are the ones that came with the LSD. The right side went in no issues but the right....I have happened the fk out of it put it in a press and it still sticks out about 5mm too far. It was sticking out about 25mm but after bashing it like Chris Brown did to Rhianna I managed to get it a bit further in but seems stuck again now. Any ideas? Should I just leave it 5mm out and send it?
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
