Amazing results, credit to you and your research.
If you don't mind me asking, What is your daily job? Do the skills from that job help you at all in the design and build of this motor? Or is this solely an enthusiasts desire to get the best results possible?
I do computer/network management and programming for a living. For the past 10 years I have been primarily supporting engineering firms. From that I have had a lot of exposure to engineering principals, CAD systems and CNC. As well as engineering support from some very clever people.
Add to this that I have been building engines of various kinds since before I could hold a license.
I've decided to get a set of Supertech valve springs for this current engine to sort out the valve float issue, and hopefully punch through that 500kw atw limit. Then maybe also a switch to an EFR 9180 as well.
Truly epic thread here! So thorough and well thought out.
A pleasure to read it from start to finish. If/when you make this a "kit" I can only hope I'll be in a position to get a setup like this for my 33 GTR.
Keep up the great work.
  • 4 weeks later...
Great thread. Have spent the day reading through!
Amazing GTR.
Look forward to updates/ more pics.
Are you running stock gearbox?
Dan
Thanks Dan.
Not much to report other than that I am going through E85 like no tomorrow. I must do a video of what the car drives like. There is a little maintenance to catch up on, needs a wheel alignment and balance, but other than that its still going strong.
Yes its still a stock getrag for the moment. Basically I'll drive it like this until next year some time when it will get an OS88. The drag strip is still being built, so I wont be breaking the getrag anytime soon.
The main focus is on the next two engines now, which will hopefully be finished around November.
  • Like 3
These next two engines are about stress testing the design. Both are being built with a 1000+hp power goal in mind. No expense spared, with a focus on maximum strength for all components.
Once testing has proved the design holds up for the first engine, the second will become available as the first to ever be sold.
  • 3 weeks later...
I am still in the process of getting the final parts made for the next two engines.
One of the two cylinder heads is ready to go. Ported, oversize valves, 280x11.5 cams, dual springs, the works. The second head is still being made, and in comparison it makes the first one look like stock. I am told it will flow past 1kw with ease.
Two crankshafts have been completed and are ready to install. One 87.8mm and one 89.8mm, both with 19mm GTiR journals and clearenced for oil squirters.
Two N1 24U Blocks are now partly composite resin filled, and are about to be sleeved and fitted with girdle plates and main caps. Then onto final bore/hone machining once the pistons arrive.
I am hopeful that I will be assembling engines early to mid December.
Edited by GTRNUR
  • Like 2
  • 1 month later...
I am still waiting on pistons for the next two engines. It took quite some time to get the specifications sorted out for something that will handle extreme punishment for an extended time. In the end I went with a custom JE and Trend DLC coated gudgeons. I'm told they will handle 1800hp+, with a specification normally found in a methanol engine.
I completed the rear R35 GTR brake conversion, and have a functional hand brake thanks to modified Toyota Rav 4 hand brake shoes.
Other than that I have been working on the front suspension lately. I've changed the lower control arms to R33 GTR items, so I can use adjustable tension rods. I've yet to locate or make a set of roll centre correction spacers. Upper arms will be fitted with superpro offset bushes to correct camber.
I've also done the first plug change and compression test since the tune. Dry test and every cylinder is within 3psi, which is amazing. The best leak down and pressure test result I've ever had. Then I re-pressure tested the entire intake side of the engine and found the reason I didn't break 500kw in the last tune session. At some stage between the first and second tune sessions, a weld had developed a small crack in a pipe that links the turbo to the intercooler. So essentially I made 610hp with a serious induction leak. I've had to turn off boost control now too, as it hit boost cut on the first drive once the leaks were fixed.
I believe the leak was in part due to a mostly torn through nismo engine mount, as there has been other signs the engine has moved a little too much. I was blowing off pipes during dyno tuning, but also, the plenum has made contact with the clutch master cylinder at some stage.
I changed my first front inner CV boot too. What a fun task that is.
That's all for now.
  • Like 1
  • 1 month later...
Update time!
Today truely a great day. With the boost issue fixed Trent from Mercury Motorsport was able to get the engine to perform as I had hoped, and we finally got the 500KW ATW goal.
We had a couple of minor issues with blowing off intercooler pipes again, but other than that the car performed flawlessly.
Huge thanks to Trent @ Mercury Motorsports and Daniel Stephensen from LK motors for performing all the tuning and dyno setup.
526kw atw at 28psi (pipe blew off in this run).
495kw atw at 26psi
33 degrees, 82% Humidity! Stinking hot!
I never saw hotter than 86 degrees on the MFD, (Oil and Water)! My cooling sytem rocks!
Edited by GTRNUR
  • Like 2
    • C'mon! At least come kicking and screaming into the 2000s. BA XR8 bulge.
    • No such thing as E30 in Sydney servos As stated above, flex fuel is your only viable,  and "safe" option I believe
    • VN Group A bonnet buldge 🤣🤣🤣🤣🤣
    • We've updated lots of Nismo items and accessories recently! Nismo in Japan don't keep a lot of stock on hand and they sell out frequently, but they do restock frequently as well. So if you put items in your shopping cart and make payment there might be a slight delay (2 - 4 days), or on rare occasions it might take longer. At any rate if you see something that is not available, wait a few days and then try again as it will likely be back in stock. We are considering just making everything available on the website and updating each order as needed if users aren't to concerned about putting an order in for something that could be delayed. https://www.oemsoko.co.jp/collections/nismo Nismo BNR34 GT-R and R34 (2 door, manual trans) floor mats:  https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r34-bnr34 Nismo BNR33 GT-R and R33 (2 door, manual trans) and Stagea 260RS floor mats:  https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34 Nismo BNR32 GT-R and R32 (2 door, manual trans) floor mats:  https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r32-bnr32
    • AA100 and AA110 are supposedly not cross listed, not sure what the differences are. Most likely you're better off rebuilding what you have unless the housing is trashed by debris circulating in the system or significant amounts of cavitation.
