Still waiting on the clutch. I've got to chase that up today as its been a couple of weeks. It is a custom made NPC unit though and I have no idea what their turn around time is.
  • Like 1
I don't believe square, under or over really makes any difference to be honest. It is just one of those facts that IS about engines.
A lot of people have a differing opinions about what works and what doesn't. What it comes down to is more displacement is better if you are after more torque and power, and less lag. Simply because your moving more air.
This is an 89mm bore and 90mm stroke too. Although the sleeve design will support a 90mm bore still, while retaining more cylinder thickness than a 24U block would have with an 87.5mm bore.
Edited by GTRNUR
  • Like 1
What is the need for custom Ian?
Based on recommendations from Trent @ Mercury and Dan (owner of LK Motors who's dyno we used), they actually agreed on the same type of clutch and I am fairly certain it is a custom setup. There is a pull to push converter required, and I believe it uses 1 x carbon and 1 x copper organic disc although don't quote me on that. I believe it is identical to the setup in Mercury's Nitto.
To be honest I left it in their hands to sort out and just paid the bill. I've been too busy with other work this past 3 weeks, which is good considering what will end up being a 4000-4500 change over cost.
Not to mention the brand new exedy carbon twin plate that is in the car is probably a paper weight now. It would be interesting to know if it is salvageable, or if its now looking completely shagged.
Once you receive the new clutch will you be re tuning it or should it still be fine given the last was slipping?
Or just doing a power run to see numbers and confirm all is fine?
And what is the price on rotating assembly for this being it's a custom crank?
Edited by anon32
Are the plates munted on the Exedy? If they are, I would think they are very expensive to replace.
The slippery clutch is still in the car. Not sure how shagged it is yet.
Yes when the new clutch arrives the wick is being turned up.
My goal is still to make 500kw atw on a soft E85 tune, which it should do with ease. 450kw looks to be easily achievable on a low boost 98 tune. Trent wants to turn up the boost to 30 and see how it goes in top end. We'll see, I might have to go for some drinks if that happens and just leave him to it.
  • Like 1
I was lucky with this Nitto crank as it was a one-of that they had on the shelf, so I got a good deal.. Not sure why they made it either. Possibly just because...
I've just made a new crank for one of the next two engines which is 87.8mm. All up cost for that came to about $5700 I think, as it is essentially a customised Nitto Rb31 crankshaft, however using GTiR rod journals and it retains the oil squirters in the RB26 block. Prototypes aren't cheap.
Edited by GTRNUR
I'd rather not go putting any kit style guestimate pricing out there just yet. I am planning on doing 2 more prototypes.
Once they deliver some fruit, I will be asking for a production run of crankshafts and the necessary components as a bulk order. This will significantly reduce the costs as well as raise the bar on the quality of the product at the same time.
  • Like 2
  • 3 weeks later...
The new NPC clutch is here but the push to pull converter must have fallen off the boat on the way from Japan, MIA.
I did put an R35 brake setup on the car though, which makes stopping as much fun as accelerating!
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
