Hey selling my daily as i cant afford 2 cars......
1994
Series 1
170tho 94tho on Nismo Cluster
Series 2 Front end Conversion
18" Deep Dish Rims
Brand new Tyres less then a month
Black roof professionaly Painted
Spoilerless Boot Lid no Holes
Kinguawana Gt35 Type Turbo
Presicion Gate
50mm Screamer Pipe
Stainless Steel Dump Pipe
Full Exhaust
Hi-Flow Cat
Cusco Oil Catch Can with Braided Lines
Greedy Type Plenum
6BOOST Himount Manifold
Koya radiator with Blue Silicon Hoses
Custom Intake Pipe with Big POD
Black Rocker Cover
850cc Injectors
Bigger Fuel Pump
Power FC with Hand Controller
Exeedy Brass Button Clutch 1 Month old
BC Coilovers
Strut Brace
Radiator Cooling Plate
Defi Gauges
Boost
Oil Temp
Apexi AVCR
HKS Turbo Timer
Nismo 320Kmh Dash Cluster 94tho ks
Nismo Gear Knob
R33 GTR Seats Front only
Pioneer Cd player with AUX
Sony Speakers
Tuned at 380hp on P100 by PZP and 370 on 98Ulp
Just been serviced and new
clutch and new tyres fitted by Quads mods Malaga
Front bar has few marks and LHD fender has few dents but i have a spare same colour fender just needs to be swapped over.
$16500 ONO
No Swapps
https://www.sau.com.au/forums/topic/434516-fs-r33-4-door-daily/
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
