My rb25 is blowing a fair amount of blue smoke under hard acceleration. I did a compression test and it came up 160 across all 6. There is no smoke on idle or slight revving only when I give it a good rev. I replaced the turbo with a brand new one and the return doesn't seem clogged or anything. Has all brand new feed and returns. Also I don't have a down pipe on it at the moment and it doesn't make full boost until about 5500 or so on a t04e. The blow off valve doesn't go off and there is no sound of releasing pressure when off the throttle. All cooler pipes are tight. What would be the cause of excessive blue smoke?
https://www.sau.com.au/forums/topic/434537-rb25-blue-smoke/
it has a brand new turbo on it with 1.2mm restricter, what are the signs of bad valve stems? ill give it a boot full and it will blow a shitload of blue smoke on hard acceleration, but if i keep boosting it the smoke gradually gets less and less, so pretty much the more i flog it the less it smokes so to speak (no i dont flog it all the time lol)
which leads me to believe its valves as theres no time for vacuum to draw oil through the seals.... but theres no smoke on start up or just putting around under say 3.5k rpm
https://www.sau.com.au/forums/topic/434537-rb25-blue-smoke/#findComment-7101937
I have had to install two 0.9mm restrictors to some Garretts just to stop the oil pumping out of the seals, you can tell as the oil is unburnt in the dump. If it is burning it, it is most likely internal, but check the intake for oil first, it could be the compressor seal or just leftover oil from the last turbo failure...
T04e is a pretty big turbo, I hope you haven't done the ring lands from booting it without tuning first. It will also be more responsive once it's tuned properly.
https://www.sau.com.au/forums/topic/434537-rb25-blue-smoke/#findComment-7102089
As stated above, potentially the oil control rings. Possibly also valve stem seals - will a leakdown test return poor figures if valve stem seals are shot? Or would they not allow enough air past?
Your other symptoms like the BOV are almost certainly unrelated :)
I'd start at the beginning of the system (filter and intake pipe - rocker breather return) and work your way to the exhaust. You've ruled turbo seals out (well, you haven't - but would be f**king horrible bad luck if you had 2 buggered turbos :P), so that leaves you with the rocker cover breather return, valve stem seals, and oil control rings to point at.
https://www.sau.com.au/forums/topic/434537-rb25-blue-smoke/#findComment-7102998
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
