  • I would also love some information on Osirus ($700) versus Haltech Platnium Pro ($2500) versus Greddy e-manage ($$??) on NA setup.
Are the above management systems compatible with our Japanese based 350GT's, as most information I found are based on G35's in America and if so what are the options for future Forced induction routes ?
Here are some places with Dyno's....i guess that means they do tuning too.... Tunehouse, IS Motor Racing, Pulse Racing, Croydon Racing Developments, Autotech, CV Perfomance,Leading Edge Motorsport, Power Tune, Insight Motorsports
Any help from other experienced members would be greatly appreciated.
So much to learn.. : )
https://www.sau.com.au/forums/topic/434598-tuning-v35/#findComment-7097013
They are all very different systems.
Osiris is a re flashing cable and software
Haltech is a standalone, but will need stock ecu to run some things
Greddy is a piggyback
It's easy to get Osiris to work with jap ecus. Most are mapped, but it's possible to add cars too. It's 700US plus shipping for the tuner cable.
I would recommend DVS Jez at Gosford for tuning, but unigroup also tuned uprev stuff.
  • Like 1
https://www.sau.com.au/forums/topic/434598-tuning-v35/#findComment-7097200
Oh, and regarding forced induction, uprev will do anything easily on a stock motor. The limit of uprev is that is has to run a afm.
It will run any size injectors if you want to run 2000s, but it still needs a afm. I found the stock afm was just about out of range at 6psi. Uprev sell a tweaked afm, that will handle significantly more flow, but the car will need to be tuned with it. That would be a 500 or so hp afm. So, anything you want to do on a stock motor, uprev will do. If you want 600kw on a built motor, then uprev isn't the best option as you need to run MAP
https://www.sau.com.au/forums/topic/434598-tuning-v35/#findComment-7097536
You can get the Uprev Osiris from East Coast Customs in QLD, I tuned my car with the standard version ($500) that comes with 3 e-tunes (record data-log and rom files, send to East Coast Customs, they tweak the rom file accordingly and send back to you to upload to your ECU). Obviously its not the best or accurate way for tuning, but it suits my purposes and the tuner version ($700) has plenty more parameters you can adjust by yourself or a dyno tuner.
https://www.sau.com.au/forums/topic/434598-tuning-v35/#findComment-7100592
i am currently tuning my v36 with uprev tuner by sending datalogs to the usa, i did run into a problem tho. After i reflashed the ECU, hood open warning light is on permanently for some reason. other than that the progress is going along slowly, i will put it on dyno and get some numbers when its fully tuned.
https://www.sau.com.au/forums/topic/434598-tuning-v35/#findComment-7115087
Take a look at this: http://www.uprev.com/documentation/Popup%20Hood%20Reset.png
Can be a pain to do (sometimes takes me 5-6 tries), but it does work.
https://www.sau.com.au/forums/topic/434598-tuning-v35/#findComment-7115097
when processing this procedure, does the uprev cable has to be connected to the car? Or i can just get in and follow the steps as followed.
Sorry abit noob to this, thanks
https://www.sau.com.au/forums/topic/434598-tuning-v35/#findComment-7115137
No need for the uprev cable. That image looks like it's taken from the service manual, not made by uprev
https://www.sau.com.au/forums/topic/434598-tuning-v35/#findComment-7115206
  • 3 weeks later...
My uprev flash has been completed. Very happy with the result. My car was running abit lean with abit of extra juice it made a big difference in torque at lower rev band so the car takes off much quicker. The engine is much happier to rev and tuner also switched the cooling fan system on at 95c instead of 100c.
My mods are stillen high flow cat, megan racing cat back, k&n filter.
Bought the uprev package from ebay. http://www.ebay.com/itm/Uprev-Osiris-Tuner-package-with-FREE-ETUNING-and-FREE-shipping-/141011901348?pt=Race_Car_Parts&hash=item20d4f6dba4&vxp=mtr
The seller is quick to respond and all you have to do is datalog with cipher and send it to him. He will send you back a modified rom file and as well as a back to stock rom file.
  • Like 1
https://www.sau.com.au/forums/topic/434598-tuning-v35/#findComment-7136585
HEy Guys I Have 2005 250GT Sedan VQ25DD Engine, my Mechanic told me that i could not tune this car from stock, would this be possible with this osiris Uprev, has anyone had any experience with it with similar/same cars as me?
Cheers
https://www.sau.com.au/forums/topic/434598-tuning-v35/#findComment-7137087
I don't think it's possible with the DD, you have much the same ecu as the M35 Stagea.
There was a guy (Baz?) selling an aftermarket ecu for the DD, it was a few months ago but I think he still has it. Look down the threads a while and see if you can find it. (Could have been in the Stagea parts section.) Otherwise you might be able to run an emanage ultimate?
If you are chasing more power, you bought the wrong engine. Perhaps start by cleaning the intake for more performance?
https://www.sau.com.au/forums/topic/434598-tuning-v35/#findComment-7137099
    • Back on topic for you for a post Will it be on pump or ethanol? 2025 Spec RB build: G30 660 .83 would be good  artec manifold turbosmart 45mm external gate 1000cc Injectors Kelford cams 264 and springs Pistons and rods for insurance Oil pump with billet gears Headdrain and all good oil mods Quality intercooler 3.5 inch dump pipe to decent exhaust Link plugin Ecu or what ever your tuning is comforatble with Bolt on Trigger Kit - Nzwiring kit is go to ARP Headstuds Quality headgasket quality fuel pump- a TI/walbro 525lph PWM would be the go Quality fuel reg Will be over $15K AUD Enjoy the noise of rb on gate at over 7400rpm. Start looking for gearbox conversions if your hard on the gear. Now I've been there and done that with rb powered street car (2007-2022) much prefer newer stuff. Anything 90's Japanese is not a great experience these days and highly over rated. My 2015 Brz with a heap of suspension mods is such a better car even with out the power of my old s chassis' even on track. If wanting to play light chassis and decent power for a  giggle a k swap 86/brz would be the go Check my old build for engine stuff I really need to pay attention to post 2016 BMW stuff but seem all very heavy 1600+kg
    • I mean, the 240i is not a Supra... make it drop a few hundred kg, have a sportscar chassis, clearance for wheels etc... Maybe I want a hardtop Z40i XDrive or something :p I do agree with you though and have long said the B58 Supra/240i/340i/440i is the new R Chassis/JDM90's turbo rocket for mod lovers to ... not always appreciative response lol. Doesn't make it not true though.
    • I will do the build myself but I will be paying for the tune because I don't know how much about that and would rather it be done right and by a professional
    • Will you build and tune it yourself or do you need to pay for labour?
    • Mechanically that's essentially what the M240i is, it's just not pretending it's not a BMW
