Welcome to the Geelong Revival Motoring Festival
The Geelong Revival Motoring Festival focus is on promoting motoring culture. With an open-minded approach to what’s cool in the area of classic, retro, performance, prestigious or just plain odd. This focus not only applies to the racing but also the Classic Motor show, Market and Fashion. If its motoring, retro or old school the Geelong Revival Motoring Festival is the event to celebrates this.
The Geelong Revival is one of the largest motoring festivals in the Australia – a unique 2 day event that brings together a unique mix of cars, motorcycles, fashion and motor sport to create one of Australia’s largest car culture events.
Join us to see over 500 classic and exotic cars and bikes on display, 300+ racing in quarter mile sprints along the Geelong waterfront, Motor Expo, Entertainment, Music, Food, Fashions on the field, Market, kidzone, Gala Dinner, prizes and more! Entry is FREE.
The Geelong Revival Motoring Festival 2013 starts on Saturday 30th November as the bay awakes to the rumble of engines, with racing commencing from 10.00 am through to 7 pm along Geelong’s fantastic waterfront. Saturday will be contemporary cars with Sunday reserved for the great machinery of a bygone age of racing glory.
The Shannon Classic Motor Show Hours
Saturday 30th Novmeber 10am – 5pm
Need to be in by 8am on the Saturday this will be updated closer to the date
We would like to ask everyone from SAU to post up there interest as we have limited spots and would love to show case different models from the club R32, R33, R34, R35
We have 10 spots to fill and because SAU VIC is paying we need to make sure that if you say you’re coming you are!!!!!!!!!!!!!!!!!!!!!
What you get!!!!
Free entry to the motor show
Pit Pass
A wonderful day in the sun down the foreshore relaxing enjoying the day.
We need to get photos of your car posted here in the thread so we can choose the cars
https://www.sau.com.au/forums/topic/434650-sau-vic-geelong-revival-car-show/
with the sprints that would mean you out of the car show but sure mate you could see thier website
www.geelongrevival.com.au
But would love to have the 34 there with us
We are doing well guys Ill keep adding people till we get to ten cars if we get more then ten we will let people know who got in.
R32GTS-T-
R33GTS-T-
R34GTT-
R32GTR- OYEAHA white (friend)
R33GTR- BiggsT purple
R34GTR- OYEAHA white
350GT - nissa350GT silver
R32GTS-T-
R33GTS-T- HEKT1K
R34GTT- Charles89
R35GTR-
Stagea -
S13 -
S14 -
S15 -
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
