I'm selling my 1998 R34 GT-T which has done 105,000km and has had regular oil changes in the 5 years I have owned it. I'm the second owner in AU since import.
** The car has front end damage ** - About 2 years ago I had a front end crash which pushed the radiator into the engine fan and totalled the headlights, reo bar, radiator, bonnet and front bar. Rather than fixing this properly, I was lazy and went out a bought a new front bar, reo, xenon headlights, radiator, and carbon fibre bonnet. I pushed out the bar that the radiator sits on with a jack, slotted in the new radiator, bolted a new reo on, then zip tied the headlights and front bar on, and replaced the bonnet and intercooler with a brand new ones.
The car is used as an everyday work car so it is driven from Crafers in the hills to town 5 days a week and rarely driven on the weekends, so it's pretty much just wasting my petrol money. I have been pulled over about 4-5 times since the crash and have not been defected, although it could be defected if a cop wanted to be a prick, but so can 95% of the cars on the road.
I spent about $8000 at once in mods about 18 months ago and had it tuned to 260rwkw. I've listed the mods that I had done all at once:
Exedy heavy duty clutch
GT-70/36r Turbo
Greddy Profec B 2 boost controller
Z32 air flow meter
Denso high flow fuel pump
Nistune chip
Splitfire coil packs
3 inch cat-back exhaust
3 inch custom dump pipe
3 inch custom cat
These are the other mods that have been done to the car before the above:
New bushes and tie rod ends
BC Racing coilovers - bought off justjap for $1,100 three months ago (only done a few thousand km's)
HKS blow off valve
Front mount intercooler (black stealth style)
Apexi turbo timer
Shift light
Air/fuel ratio meter
17" mags
Carbon Fibre vented bonnet
Small aero side mirrors
Xenon headlights
Clear side indicators
Full fibre glass body kit
Rear seats and seat belts removed - can supply
B-pillar lock bar (Room bar)
Front roll bar
Front upper adjustable camber arms
Rear adjustable camber arms
I may have missed out a few things but as you can see it's had a decent amount spent on it and is ready for drift or track, just needs a retune. You could just keep it as it is and drive it like it is, or spend the time on fixing the front end properly.
I'm asking $12,000, and I will consider swapsies with a 4x4, preferably a patrol or navara. Give me a text or call on 0431516718 if interested.
Cheers,
Tom
https://www.sau.com.au/forums/topic/434654-12k-r34-gtt-lots-of-mods-adelaide/
  • 3 weeks later...
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
