Hey peeps.
Have an odd issue with my m35. When full throttle revs will hold at around 4000 for a second and then start accelerating as normal. Mainly happens when in sequential mode.
My mates is doing the same thing but has only just started doing it. He has transgo in so that doesn't seem to be a fix for it.
Anyone experienced the same thing or know what is going on?
https://www.sau.com.au/forums/topic/434674-m35-rev-issue/
Ok im having odd rev problem. Just had throttle body cleaned and spark plugs replaced. Car revs at 1250 idle and drops to 950 in drive but feels like throttle is open slightly as car wants to accelerate on its own. Do I have to reset anything after getting this done? I aslo put car into drive and took foot off brake petal. Car throttle kicks in and out without touching accelerator. Any help would be great
Edited by joshm35
https://www.sau.com.au/forums/topic/434674-m35-rev-issue/#findComment-7100381
It might be worth trying another one, to see if it goes away... Now that the plugs are good. :P
Put the old one back in... And I rekon it feels better.... Revs cleanily, not sure about the smoke, mirrors and back window are now filthy after spending time at Officer railway station...
Not sure what the hell is going on there...
https://www.sau.com.au/forums/topic/434674-m35-rev-issue/#findComment-7103411
  • 1 month later...
Hey Josh, Did you find a solution to this problem. My car does exactly the same thing. Idles at 1250 and 950 in Drive. I went driving into Surfers the other night and she likes to drive at about 30 kph in drive without any throttle.
https://www.sau.com.au/forums/topic/434674-m35-rev-issue/#findComment-7154392
You need to do the idle relearn.
https://www.sau.com.au/forums/topic/434674-m35-rev-issue/#findComment-7154412
Yeah mate as dale sad I had to do a relearn.my mecanic sorted it t on his consult II. The car have to be at a certain running temp and whatnot before it would let him do it. All sorted now.
https://www.sau.com.au/forums/topic/434674-m35-rev-issue/#findComment-7154471
If you want I can give you my mechanics number (ryan) and he can get it sorted for you? He is up my way in cleveland so not too far from you and having done some work on my car shouldnt be an issue for him as its what he has dealt with before.
Edited by joshm35
https://www.sau.com.au/forums/topic/434674-m35-rev-issue/#findComment-7154472
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
