I got some parts for sale.
GT35r with a Garret 1.06 internal wastegate rear housing (not the ford one, this housing retails for $650)
Was on a twin turbo v8 setup but the guy removed them to upgrade to bigger not long after it was tuned.
706451-5015 is the tag on the turbo. there is NO shaft play at all - same like a brand new turbo.
Looking for $1000 for the turbo.
Set of 2 rear king springs for R33 GTST, used in good condition. $70 + post
Cusco Zero1 coil overs, in great condition. 8kg and 10kg springs. They were removed from the car because they were too stiff for me for a street car. Selling for $600
Z32 ECU modified to run on R33 Rb25DET with bran new nistune board installed $550
can post anything at buyers cost.
May be interested to swap the turbo for a bolt on turbo for rb25 that can make 270kw at wheels.+
post-1240-0-21019300-1383834369_thumb.jpg post-1240-0-16926900-1383834379_thumb.jpg
post-1240-0-81871500-1383834389_thumb.jpg post-1240-0-91234000-1383834405_thumb.jpg
post-1240-0-72515300-1383834503_thumb.jpg post-1240-0-86180500-1383834584_thumb.jpg
I dont get it y $550 for the nisstune if they are less brand new?
You still need a Z32 8-bit ECU, then you need someone with delicate hands to solder the board on and cut some of the tracks, so $550 is a decent price
Jet2nv sold his for $350 a few days ago.
http://www.skylinesaustralia.com/forums/topic/434836-rb25-380rwkw-bits-sale/
Bargin.
    • Hi everyone, just looking to see what's available in the GTR seat options, testing the waters on what's available. Wanting a driver's seat to replace my old school OG jap race seat, going to re-register the car so need a factory seat. Prices currently seem to go from $300 to $2k for a driver's seat. What's options are there, that's good condition and actually a realistic price? Located Brisbane. Thanks
    • Are these a plug and play setup, and do they need a tune, like a haltech ecu etc? Thanks
    • Nice work on the paint. Those 3 studs are long as.
    • Hi everyone, still chasing a bunch of this stuff. Thanks
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
