Decision Making
hazeR33
 Share
I'm very quickly reaching the end of these god forsaken p plates..
And have owned my r33 for 2 years.. So time to upgrade her..
She stock n/a rb25 ATM
Rb30 conversion? Chuck a snale on.. Or what's the best setup for low costing
Good outcome?
 Share
    • Not much info in that request..... If you have a VIN you could look up the factory part number here: https://www.amayama.com/en/genuine-catalogs/nissan
    • 2.5 torque? 3.0 torque? Pft. Dude the van is right there. Consolidate your projects, put the LS into the R32 and have either a R32 with grunt, or a firebird that handles, however you want to refer to it. Either way you won't want to drive the Firebird or a RB powered Skyline ever again so this is the proper solution, and you cut down on projects. It makes sense even if you hate it.
    • Never mind the ash - the massive witness mark on the leading edge of the rear arch make little baby jesus cry.
    • Some small fixes made over the weekend. I've been trying to get the car sitting right on the 275's as well as reducing the rubbing as much as possible. I bought a guard roller but the lip within the guard is obviously made of high tensile steel because it took so much work and heat to get the smallest of movements that I totally flared my rear arches. It looks kinda cool.   I also got inside the arches with a dremel to cut down the bumper and the bumper mounts. The first one (pictured) got a bit ugly but the next one was much nicer as I just cut slots and hammered them upwards. I gave it all a spray of primer too. I'm still scrubbing a little bit on passenger side but it has less camber than the drivers, so once that is sorted it *should* be ok. I drop a single corner down on the ramp to simulate that mismatch and see where it is scrubbing.         Here's my flares. The car is lower than this now. Excuse the bush fire ash on the car.    I also haven't had windscreen washer jets for weeks so thought I'd tackle that. It looks like a leak is coming from under the headlight. Just in there. See it?  This would have been clearer and easier if I'd taken the front bar off, but basically the plastic hose connector has broken off the headlight sprayer. And because I couldn't be arsed taking the bar off and fixing what is already a gimmick, I just disconnected the feed hose and with some aquarium hose, circlamps and a drive shaft bolt I fixed it good. The hex piece I tried first did not seal too well (2nd pic) - not sure why I thought it would! 🤦‍♂️.   Because I hate things being broken, I will fix this, but until I could be bothered to take my bar off, this will suffice. Note the BMW push-in hose connector. Because standardised fittings are too passé. I now have an issue with my adaptive headlights always pointing too low and sometimes shaking back and forth when I'm driving. I'm keen to have these working properly. On another note, I bought a set of EBC BlueStuff for the front. I looked at so many reviews; DBA Xtreme (not enough reviews), Ferodo DS2500 (Super expensive and hard to find), Hawk HP+ (hard to find, not many track/street combo reviews) and some others. Was able to get the Blues pretty cheap (~$250 delivered). Also there's a motorsport joint in Hornsby that will supply and install a RacingDiffs LSD conversion for $850 which is pretty good. I know its not a proper LSD but I'm just not keen right now to spend $3500+ on a proper one. I figure I'll give this a go and see what its like, if nothing breaks I can sell the diff with this in and upgrade later if I want. There are some streets near me I cannot get up in the wet at all and just spin a lot in the dry, it would be nice to have traction on these. (I live on a big hill). My first ever skid pan is coming up on the 8th of Nov. Can't believe I've never done one. Really looking forward to it.
    • He hasn't been seen here since the day of the above post.
