Hey guys
Having a slight issue with my 260rs stagea
just whenever im driving and im at say 3000 rpm or upwards
if I clutch in to slow down (so the revs drop quickly) the engine cuts out and stalls
but if I engine brake and bring the revs down gradually there's no issue at all
any ideas??
Thanks guys
https://www.sau.com.au/forums/topic/434818-rb26-stalling/
yea i already tried 2 known working afms with no difference =/
other thing i noticed yesterday is ive got oil spray that looks to be coming out of my dipstick tube, which ive nailed down to bad PCV valve
im going to change the PCV valve anyway but do you think that could have something to do with it?
https://www.sau.com.au/forums/topic/434818-rb26-stalling/#findComment-7105866
Yea its still on the factory set up so recirculates back to just before the turbos
I've already tried a pair of new bovs (26's have 2) with no difference
But its more related to rpm that boost pressure
example if im just rolling at 4k rpm, so im on vacuum it will still stall out if I clutch in or shift to neutral =/
https://www.sau.com.au/forums/topic/434818-rb26-stalling/#findComment-7106587
Have u cleaned ur aac? Sometimes the solinoid sticks and doesnt open the air valve. Easy way ro check is on idle unplug it and if it drops off u have found ur cause. Could also be the tps not telling the computer that the throttle is closed. Basicly an on and off switch.
  • Like 1
https://www.sau.com.au/forums/topic/434818-rb26-stalling/#findComment-7117546
boom! simple as that got it sorted by the looks of things :)
pulled the aac out and gave it a clean plus a dose of some WD-40 and so far today it seems to be driving fine
as well as that ...the other issue i had with the oil spraying out of my dipstick tube seems to be gone too.... seems odd that they could be related doesnt it ?
I got the same problem with r33 (rb25det)... Using my ecru software I monitored the car when it does it and the voltage readings drop to low 13's.
got mine sorted no worries .....worth having a look at maybe
  • Like 1
https://www.sau.com.au/forums/topic/434818-rb26-stalling/#findComment-7118732
Hopefully it's gone for good!
https://www.sau.com.au/forums/topic/434818-rb26-stalling/#findComment-7118733
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
    • We have one that holds 2.8L of water. On floor carpet that hasn't been touched in 2 or 3 years, will take a minimum of 2 fills of the tank to do a bedroom, and that's going AROUND the bed.   In the cruiser, I used an ENTIRE 2.8L tank, just on the front passenger footwell. But it had some fungus growing, and had been full of mud from being used as a 4WD for many years. I can do that floor again, and it will still pull mud out. However, the water now only looks dirty, not pitch black and leaving full sludge in the bottom of the tank it sucks back into. Oh, and, this is about a $1500 unit.
    • This is mine, works a treat for the cars, suction is good, I use the Bissell clean and protect stuff I have found giving it a good spray and light scrub with the soft brush on the head of the nossle for carpet, and a rub with a microfibre for cloth seats and cloth door trims, prior to another quick spray before vacuuming it up works the best @GTSBoy You would surprised on what it gets out of carpet and seats that actually "look" clean, I recommend that you test drive yours when you have a little time to kill, then post pics of the muddy looking water that I believe you will find
    • I think even the "commercial" capacity ones that you would hire from supermarkets etc wouldn't have the capacity to do all that much in one go. I will go through half a dozen tanks of solution and dumps/rinses of the waste tank for one little 2 seat sofa. Or similar for one 6 footish rug. That's the price you pay for something small that only takes up a bit of cupboard space, instead of something that takes up the entire laundry cupboard or half the shed.
    • Someone needs to copy it, improve it aesthetically, make it DBW ready from day 0 and send it to the motherland Chynah for my relatives to cast it and mass produce it 😅
