Hello everyone, first post on the forum. I live in California and I'm trying to get some info for a project of mine. I have a 1973 Datsun 240z that I'm attempting to install an RB25det NEO engine and 5 speed transmission into. I am having a heck of a time finding a "HowTo" for wiring a NEO engine. I do not want to pay to have a harness build as I'm quite capable, provided I have the info I need to complete the job. I have been scouring the internet looking for any sort of well written how to on the topic. While I was on another forum I saw a member there who had received lots of help from a member of this forum. The member heres name is Simon, but I do not know how to get in contact with him. I'd like to speak with him to see if he would be willing to share some info with me. Below is a link to the other forum post I'm speaking about and in it you will find the reference to Simon. Simon is not the only person I'd be willing to take Info from, ANYONE with the information that is willing to share with me would be greatly appreciated. I am just looking for a basic (These are the wires you will need, ie: color/pin number, to apply switched power, ground, constant power ect) type of help. I appreciate everyones time and hope to have this project on he road soon, given your help.
http://forums.nicoclub.com/my-r34-rb25det-neo-f3-plug-pin-wire-colors-still-confused-t542427.html
Thanks again.
Thank you. I'm digging through the many many pages as we speak, trying to find the info. I'll also try contacting simon-s14 to see if he can help, if he is infact the simon the forum was speaking of.
I looked through that post and it is so long that I cant seem to find the info I'm looking for. But it made for good reading nonetheless. I also sent Simon-s14 a message. I hope to hear from him when he gets a chance. I'm going to go back through that 62 page posting looking for the info I need for my project in the mean time.
If it was my car, for the money its costs (in cal) a proffesionally made custom wiring loom would be the quickest / easiest solution
Might even be one "on the shelf"
To be honest, if I knew of a shop here in Cali that would do it for a reasonable price I'd consider going that route. The car is currently my daily driver so the less down time the better. I don't want to pull the stock engine until I'm confident that the RB is ready to drop in. The sooner the RB is ready the happier I'll be, however paying some shop (No matter how great a job they do, not knocking) $600 for a harness when I could make the same harness myself with a little info, is out of the question. I'm not against doing work the hard way (with wrenches and a soldering iron rather then with my wallet) in fact I prefer it because it gives me a since of accomplishment. But in the end, the car just needs to run and if there is a shop semi local that can do it for a reasonable price I'd happily give them my money. I'm still hopeful that Simon will chime in or I.M. me and spread a little knowledge my direction. I'll keep searching in the mean time, hopefully I'll be able to figure this out sooner rather than later.
Hello again everyone. Sorry for the delay, I have been working late these past couple days and have been unable to work on the wiring lately. So I found the post you listed (Thanks for posting it again anyway) and I have been trying to follow DJRIFT's instructions however I'm having a heck of a time. The first two wires he listed (The white/green and the white/black) were located, however I can not find the 3rd wire he lists to power up. He says to locate a Yellow/red wire just inside the firewall grommet and power it up via a 50amp fuse link. Well the only yellow/red wire I can find is a small gauge wire and when tracing it, it traces back to pin #20, which is (According to the wiring schematic) as the crank signal. In DJRIFT's how-to, he later says to power up pin 20 with switched power. So the wire I wound is obviously NOT the wire he is referring to when he says to power it up via a 50amp fuse link. After this hiccup, I'm worried that I may run into further issues. No offense to mr DJRIFT, perhaps the car he worked on was wired with different colors then my engine. Does anyone have any suggestions? Thanks ahead of time for the help.
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
