hi
1. i have camber arms and traction rods to go in the rear of my R33 GTST and the bolts to undo the camber are so tight i am worried i am gonna strip them -
question is, is there any tricks to get em off ? or suck it up and tried harder - just feels like i aint getting anywhere - plus my local sterring and suspension mob want $440 to replace them.
Q2. i have just replaced my brake shoes and i am testing them and they seem to be moving (working corectly) so i put a rotor on and tried the handbrake and it still seems very light - its dosnt get tight as i lift it up plus i can still spin the rotor once it is on.
could it be it needs tightening?
if so what is it i am tighting ? pls point it out in the pic below - because the only thing on each shoe that looks like i could turn is actually a pin holding the shoe..
if someone could point it out in the pic that would be helpfull
( my handbrak failed after two hits on my last drift day - went basically limp and weak ) please ignor how untidy they currently are -
Edited by Reese69
https://www.sau.com.au/forums/topic/434835-2-questions-help-pls/
i can not see anything there that adjust the shoes -
dose anyone no of a pic that can show me what i should be adjusting -
the above pic is of my R33 gtst rears and i only put in new shoes and everything is there..
as i mentioned above post i was drifting and used the handbrake 2 times then it went limp and only just worked when handbrake was fully on (well i could feel it wokring but didnt do much) handbrake still feels the same like the handbrake is just going through the motion not locking-
any help or ideas
There should be an adjuster at the bottom - between the 2 brake shoes. When you turn the toothed wheel, it screws the ends in or out (ie gets longer or shorter) depending on which way you turn it. This pushes the shoes in or out.
mmmmm thats what i thought i seen in a pic i found but i dont have that on eirther side....
ill double and tripple check the work area but i dont remember seeing it - must have come out when the brake failed but the chances both falling out are fairly slim?
dont you think ?
There is an adjuster on the brakes that looks like this:
You need to put the rotor on, it will have a hole in it (usually covered by a rubber grommet) where you use a screwdrive to turn the above adjuster, I cant remember which way is tighter (up or down) but you can probably work this out before you put the rotor on then do it
Usually you do it up till the rotor starts going tight then back it off 2-3 notches or so. Just make sure the brake isnt dragging.
Do one side then do the next
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
