The comp ratio is swept vs unswept volume. Very simple. It gets much more difficult once the engine is spinng, as now the cam timing, condition of the valves and ring seals and head gasket play a part, along with volumetric efficiency, temperature etc. To figure out an unknown engines comp ratio from a comp test is never going to be accurate. Cam timing plays a huge role. If you are buying a built engine ask for the actual figures. If you are happy to assume its a high comp ratio motor based on that test, (which changed a fair bit once you asked for confirmation) by all means buy it.
^^ this! Some very very early combustion engines had low compression figures from the factory due to the low CR of around 6 to 1
Id say rob is running 8 to 1 CR as hi boost turbos ADD a lot of compression pressure to the engine therefore lowering the CR he can run (part governed by fuel octane)
Settle down. explain to me how an engine when built has a certain compression test result, then when worn had a lesser compression test result? Did it's comp ratio drop? can you run more boost cos it has less comp ratio? NO. explain how comp ratio effects the comp test results please :)
Ive compared 2 identical engines before, one with 150psi ( supposed to be 7.6-1) each cylinder and one with 180psi, and the one with 180psi cleary had more balls, the 180psi one had the head shaved which would of increased the comp ratio..
also a previous rb20det that was in nice condition, showed up as 150psi on average, showed 100rwkw without intercooler so about right I think, just for reference
Edited by AngryRB
I have low compression pistons as they were lying around the shop at the time of my low budget build. Consequently I have to run 25 psi to make the same power as others do with 18psi and high compression pistons! It was a very slow build and over time I added more expensive components to the top of the engine (what you might call the wrong way round)! If and when my engine goes bang I will rebore and fit 9.5:1 forged pistons and properly balance everything.
must be a pain to drive off boost, im keen to do a rb30det with 9.5-10-1 with e85 and a 3076, nothing worse than a sluggish motor on the streets, but sometimes you just have to do the best with what you've got..
Not at all a pain to drive off boost - accelerates quickly from 1000 rev/min in any gear. However your specs will make for a quick car!
Anyone thought about how the one doing the test could be straight up doing it wrong? Sounds stupid, I know, but hey, it happens. If he keeps cranking it until the gauge needle stops moving, it would read around the 200 - 210 mark. Some people just plain don't know how to properly do a compression test.
To OP, yes, 200+ is way, way too high. Look for a number around the 150-170 mark.
Source: Cranking my RB25DET comp gauge pressure up to 205 across the board to perform an (admittedly ghetto) homemade leakdown test just by bumping it until the needle stopped.
I take my reading when the need stops moving as per the book...
When I did my RB20DET I had two comp gauges to use, the lowest set of figures were 149 to 154 psi, the gauge that read higher also achieved a 5psi spread.
Ive never seen the guage keep getting higher with longer cranking, in the first few cranks it hits the number and after that just bounces on that number, the engine just has what it has I don't get how you can make it higher than that.
I just got the reply 210. Cold. Does this mean the head has been shaved previously
There is not necessarily anything wrong with this motor. It may be purpose built as a high compression engine designed to run on race fuel or E85. Back in my youth as a Ford mechanic we used to get cars with high compressions caused by excessive deposits and they were routinely "decoked"... not a term I hear these days. If the engine is in a car you should test drive it with some form of det detection to see if it is detonating. Ask the seller why the compression is so high - did he build it himself or know who did?
Nah its from a half cut car import mob offering start up warranty only. I dont really care about how to do a comp test coz I do know how to do it. Im wondering what are the pros and cons of having a high compression motor
Google will give you a much faster answer.
High compression is usually associated with a n/a. Low comp with forced induction. You trying to achieving any thing with 9.5ish.1 comp and above has a higher risk of detonation for your RB20det. Ideally for a force induction motor supercharged or turbo would be in the 8-8.5.1 range for reliable safe worry free function. This topic asking the pros and cons goes into a rabbit hole of controversy and opinion. Every engine builder believes what the do and how they build an engine equals to personal beliefs of religion aka everyone is wrong but themselves. I agree with Superben somewhat that no one will give you a correct answer unless you research for yourself. I hate telling someone to go "read" but in this case Google and the search function here on SAU is your best friend.
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
