Hi Guys,
I'm wondering if anyone can help me out ....
After the downpour last night, my M35 Stagea had a major hiccup and had lights and warnings going off everywhere.
Basically undriveable.
I remembered a couple of guys on here, Ian and also Andy, that showed me how to remove the battery to get at the connectors in the fuse/relay box behind it and dry it all out.
Did that today, but noticed that the 14 wire plug that plugs into the relay box had quite a bit of corrosion on it. So I went to separate the wires that run to it so I could at least spray some CRC22 in there to clean and dry it out. Several of the wires came lose and pulled out. The ends had rusted off them, obviously due to the water over the years. I have replaced the crimp on pins with some from another Nissan loom I had here, but I desperately need a picture, or color chart to figure out which wire goes where.
I have been all over the net for about 5 hours without any success .....
I would really appreciate any help anyone can offer.
Cheers
Scott
I think seasiasnure is on the right track... I would blame the ugg boots.
seriously thoe. im sure the others would have a pick, later this arvo is nobody chimed in to help I see if I can get a pick.
Tried the Ugg boots, but just got all nostalgic for NZ and started chewing on the grass ......
Couple of guys are very kindly trying to chase down some pics, so I'm sure ill get the info somehow!
Cheers
Scott
Graeme at Synergy Motorsport sent me some pics within 20 minutes !!!
So now I have everything connected, but still won't start ....
This is what I found inside the IPDM module behind the battery !
