Pretty sure you cant measure it like you suggested as the trigger voltage is only applied for the dwell duration to excite the coil each fire (3ms). You would need an oscilliscope to measure it with the car running. You could easily figure out which one is the 12v supply with your suggestion though
Edited by superben
Ok, no, it has 5v constant feed and to fire the coil it drops the feed for a ms, I've have just been informed on the computers forum it is actually 5v same as the 32/33
I have checked them and I got 12v-0v-5v in that order, but one of the guys on the other forum suggested it might be 12v instead of 5v so I thought I would check on here
thanks for the reply anyway
Glad you got your answer! But what changes when you change the dwell ? Its my understanding, and i could be wrong, that the coil sparks when the trigger voltage is removed, surely what changes is how long the trigger current is applied for before being removed.
That's right, the coil has 12v going to it full time, and 5v as a trigger, when the 5v is dropped to 0v the coil fires
I get that. But the coil is only charged for a limited time (the dwell) How is that achieved ?
That link shows what I am trying to say. That the trigger voltage isnt constantly applied, its only applied for the dwell time (approx 3ms) to charge the coil the the coil sparks when released. Hence the need to use a scope when running. I havent checked, but if with engine off and ignition on if you are getting trigger voltage to the coils that would be a bad thing and cook them, as they are charging for way too long.
ok now im on the laptop I can read it properly, yeah you are correct, I have always looked at it differently, so when you turn the IGN on the 5v feed is activated until you go to start the engine then it is dropped to 0v to fire coil then reactivated to "charge" for how ever long it needs to then dropped to 0v again to fire etc, I'm still looking at it from the coil dizzy craby days where the coil is always on and discharged when the dizzy makes contact with the points, your way would be more relevant to this situation
I was also asking for it to be checked before the engine is started, with just the IGN on, it is to check the settings on the new computer, but it looks like when someone left the key on overnight has killed the coils and battery, not me, fark
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
