[Nsw] R32 Gtr & S15 Leftover Parts Clearance
Sold the car and I've got this stuff I need to move on so its going on here. The OEM parts are from 1993 R32 GTR with 120,000km
1. S15 Silvia/200SX pair Rear RDA slotted rotors with metal backing plates (thickness unsure) FREE
2. 4x S15 Silvia/200SX Rear brake calipers 3 of them are leaking and have been disassembled 1 of them still operating fine. Have 3 used Nissan brake pads to go with them and also have handbrake cables attached $20 the whole lot. Picture is of the 1 remaining caliper that operates fine.
3. Endless MX72 rear brake pads for all Silvias S13/S14/S15 brand new in box $250
4. R32 GTR HICAS pump. HICAS was working fine when it was removed form the car. $10
5. R32 GTR RB26DETT OEM Fuel injectors x6 were leaking fuel due to perished O-rings. New O-rings and a professional clean and test and should be good to go. $100
6. R32 GTR OEM Fuel pump. Little bit of corrosion on the surface. Worked fine when removed from car. $10
7. R32 GTR RB26DETT OEM Ceramic exhaust wheel pair of turbochargers . Worked fine when removed from car. No shaft play and very smooth. $100
8. 350mm Deep dish suede steering wheels x2. Came with my HKB boss kit that I purchased. One steering wheel has horn button other one doesn't have horn button. These steering wheels will bolt up to the same pattern as Nardi wheels. I bought a Nardi wheel to use with the boss kit so no use for these wheels. $10 if you want the horn button. $5 without horn button.
9. Old school Tomei remapped ECU for R32 GTR RB26DETT. Suitable for cars running standard injectors and AFMs. Worked fine when removed from car. Everything runs just like OEM except engine revs out smoother. Cheap and tidy way to remove 180km/h speed cut from your R32 GTR $80
10. HKS Hipermax IV GT Coilovers. Bought brand new from Japan via Jesse Streeter earlier this year only used for about 4 months and 4000km before car got sold. Complete set including cable ties, C-spanners, certificates and instructions. 7kg Front & Rear spring rates. Excellent balance of handling and ride comfort for road use. Guaranteed working 100% genuine Japanese quality. $1200
11. Professionally welded up R32 GTR Rear HICAS steering rack. Cheap and effective way to lock out HICAS without resorting to buying a dodgy HICAS lock bar. $50
12. Nismo R32 GTR steering rack bush/mount kit. Brand new in bag never installed $50
13. R32 GTR RB26DETT OEM air box including air filter. $150
14. Brand new Genuine Nissan Oil filter 15208-H890C suits R32 GTR RB26DETT and anything else that accepts the same filter. $15
15. Ryco Z387 fuel filter to suit R32 GTR RB26DETT. Used for about 1500kms. FREE
16. R32 GTR RB26DETT OEM Radiator. No leaks. Doesn't come with radiator cap. $70
17. Nismo high pressure radiator cap. Bought brand new and used for about 4 months. $25
18. Apexi RSM Blue version. Unwanted extra given with other purchase. Was assured that it works from previous owner. $50
19. Genuine made in Germany BBS RS RS261. 17x9 +20 offset with centre bores made to 66.1mm to suit Nissan hubs so no hub rings required. Includes centre caps. Contisport3 tyres 225/45/17. 2 completely bald and 2 with minimal tread left. Light gutter rash on some of the wheels. Not sure what these are worth since they are quite rare. $1800 or reasonable offer
20. Intima SR low dust rear brake pads to suit Silvias S13/14/15. Used for about 3 months estimate 85% meat left. $50
Contact via PM.
Pickup in Sydney Metro area.
Free items are pickup only.
May post at buyer's expense.
NISMO RAD CAP SOLD
TOMEI OLD SCHOOL ECU SOLD
Photos of the steering wheels added:
350mm Deep dish suede steering wheels x2. Came with my HKB boss kit that I purchased.SORRY NO HORN BUTTONS can't find it. These steering wheels will bolt up to the same pattern as Nardi wheels. I bought a Nardi wheel to use with the boss kit so no use for these wheels. $5 each or free if you buy something else and pickup.
Found some more stuff to sell:
Cusco Rear upper camber arms to suit R32 GTR ONLY. Bought new in May this year, used for about 4 months. Great condition $250
Cusco Rear traction arms to suit most Skylines and Silvias. Bought new in May this year, used for about 4 months. Great condition $250
Edited by chris86
  • 1 month later...
  • 1 month later...
Update to what's still left for sale. Everything else is gone.
R32 RB26DETT GTR Fuel pump (worked fine swapped out for high flow pump) - FREE or goes in the bin
R32 RB26DETT GTR factory fuel injectors (replaced because leaking) - $80
Cusco rear upper camber arms to suit R32 GTR (almost like new) - $170
Cusco rear traction arms to suit most Nissans (almost like new) - $150
Endless MX72 rear brake pads for Silvias S13/S14/S15 (brand new) - $100
R32 RB26DETT GTR factory Radiator (wasn't leaking swap due to upgrade) - $20
S15 SR20DET factory Radiator (wasn't leaking swap due to upgrade) - $50
Nissan RB26DETT Oil filter (brand new) - $10 or FREE if you buy something else
R32 GTR RB26DETT factory turbochargers (worked fine swapped out for Garrett -7s) - $50 for the pair
R32 GTR welded up HICAS rear wheel steering rack (simpler way to delete HICAS) - FREE or goes in the bin
R32 GTR engine bay HICAS pump (no issues removed due to HICAS delete) - FREE or goes in the bin
S15 rear brake calipers (3 broken & 1 fine) - FREE or goes in the bin
Genuine Nardi Classic 360mm black leather steering wheel with genuine Nardi Horn button & HKB Boss kit to suit R32 GTR (like new) - $300
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
