Just some left over parts that are not needed. Located in Melbourne. Most items can be posted at an additional cost.
Cusco strut tower bars suit R32 Front and rear. Avg condition. Scratches and paint chips. $180 pair
HKS Boost gauge and GReddy A-pillar pod Up to 2bar. Suits R32 dials perfectly with black back and red needle $160
Sports steering wheels (leather) 1. Momo, good cond, leather not worn through. 2. Unknown Italian brand, carbon inserts. 3. OMP style deep dish blue stitching, hardly used $40 each
Antenna booster - 12V amplified New. Boosts weak FM radio signal (10dB gain). Problem particular to R32's where the antenna is built into the windscreen. $25
CUSCO springs (from Zero 2E coliovers) Cusco ID65 200 series. Spring rate: 11kg, Inner spring diameter: 65mm, Length: 200mm, Stroke: 100mm. Travelled 2000kms $120 pair
A'PEXi ECV (Exhaust Control Valve) and cat Control the loudness of your exhaust. Approx 40% reduction on my 3" exhaust. Catalytic converter is empty / gutted. $90
Child anchor points and brackets Fitted onto rear parcel shelf during compliance process $20
Oil catch can Never used. Looks about the size of 500ml. $35
Blaupunkt CD/MP3 Head unit Excellent condition. Detachable face. Anti-theft features. Comes with loom plug $70
Hks Electronic Torque Split Controller (Hks Etc) And Hks Electronic Drag Adaptor (Hks Eda) $620 pair
Pics available for all items!
https://www.sau.com.au/forums/topic/434937-random-aftermarket-bits-and-pieces/
got a picture?
got a picture?
On closer inspection I dont think this was APEXI. Might be Autobarn Driftek branded. Been sitting in storage for a while I cant remember
so it replaces the cat?
Hey mate could you please send me a picture of "HKS Boost gauge and GReddy A-pillar pod Up to 2bar. Suits R32 dials perfectly with black back and red needle $160"
  • 3 weeks later...
  • 1 month later...
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
