Just some left over parts that are not needed. Located in Melbourne. Most items can be posted at an additional cost.
Cusco strut tower bars suit R32 Front and rear. Avg condition. Scratches and paint chips. $180 pair
HKS Boost gauge and GReddy A-pillar pod Up to 2bar. Suits R32 dials perfectly with black back and red needle $160
Sports steering wheels (leather) 1. Momo, good cond, leather not worn through. 2. Unknown Italian brand, carbon inserts. 3. OMP style deep dish blue stitching, hardly used $40 each
Antenna booster - 12V amplified New. Boosts weak FM radio signal (10dB gain). Problem particular to R32's where the antenna is built into the windscreen. $25
CUSCO springs (from Zero 2E coliovers) Cusco ID65 200 series. Spring rate: 11kg, Inner spring diameter: 65mm, Length: 200mm, Stroke: 100mm. Travelled 2000kms $120 pair
A'PEXi ECV (Exhaust Control Valve) and cat Control the loudness of your exhaust. Approx 40% reduction on my 3" exhaust. Catalytic converter is empty / gutted. $90
Child anchor points and brackets Fitted onto rear parcel shelf during compliance process $20
Oil catch can Never used. Looks about the size of 500ml. $35
Blaupunkt CD/MP3 Head unit Excellent condition. Detachable face. Anti-theft features. Comes with loom plug $70
Hks Electronic Torque Split Controller (Hks Etc) And Hks Electronic Drag Adaptor (Hks Eda) $620 pair
Pics available for all items!
https://www.sau.com.au/forums/topic/434937-random-aftermarket-bits-and-pieces/
got a picture?
got a picture?
On closer inspection I dont think this was APEXI. Might be Autobarn Driftek branded. Been sitting in storage for a while I cant remember
so it replaces the cat?
Hey mate could you please send me a picture of "HKS Boost gauge and GReddy A-pillar pod Up to 2bar. Suits R32 dials perfectly with black back and red needle $160"
  • 3 weeks later...
  • 1 month later...
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
