^^ been told the water line doesnt quite line up when swapping the turbos over?
Hrms, don't recall having that issue back in RB20DET boat anchor days.. I'm sure all I did was remove the stock RB20 hair dryer and just bolted up the RB25 heat gun.
  • Like 1
As for the water line, i ended up loosening the turbo off the manifold studs to jiggle the turbo to get them in, from memory.
This is helpful for anyone fitting a stock turbo its easier to do when the turbo isn't tightened up against the manifold.
Spray the nuts and bolts with a penetrating lube like penetr8 or penetrene or something first to save heaps of hassle.
Should be doing this before pulling old nuts and bolts off anyway. If you break something its not likely you can fix it on your own.
Good luck you should be fine with the swap.
What is the condition of the RB25 turbo you are fitting? remember these are very old hardware now
Its a 45v4 turbo. The guy said it was from a R33 and that is was also never boosted past 10psi.
From what I can tell it has 1-2mm shaft play without oil. Is that bad?
Ive read that they have factory shaft play of up to 1mm so that when they heat up it still spins freely? Or is that false?
What else should I look for on the turbo to tell its condition, type?
factory shouldn't have any play, the whole turbo will heat up pretty evenly so bearing tolerances shouldn't change much
1-2mm sounds about right for a 20 year old stocker. just throw it on and fingers crossed it doesn't blow smoke
a tune would get you a bit more power but probably no more than say 10kw. it would be more responsive and better on fuel but it's up to you. Your set up is on about the limit of the stock ECU.
Actually I'm not sure about the RB20 ecu's so maybe ask someone else; but it's worth mentioning that an aftermarket ecu + tune will be minimum $1250
Without tuning you will run into the same problems as anyone else winding up the boost on an RB20 would, just at lower boost levels. The factory maps are richer and more retarded up at the the high revs and high load regions than are good for making power. The RB25 turbo pushes a bit more air at any given boost level (or more to the point, the exhaust side flows more exhaust gas at any given boost level, reducing restriction on the engine which is what allows more air to flow at the same boost, if you know what I mean). So what that means is where things might start to get a bit black smokey on an RB20 turbo at 14 psi, you may reach that sort of flow at 12 or 13 psi.
In addition, you will possibly max out the injectors in a similarly early way. It isn't wise to wind up the boost without knowing the fuel pressure stays good at high load and revs and the injectors aren't bumping up against the 100% duty cycle region.
  • Like 1
Also a little hurdle you will/may come across...
The stock 20 turbo comp housing has a nipple to read boost for the wastegate actuator. The 25 doesn't. You will need a nipple welded onto your I/C piping to complete the conversion completely.
  • Like 1
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
