I'll consult a tuner before the install to look at my fuel pressures etc.
Is this nipple on the IC piping going to the intake plenum? I have a strange thing poking out of the piping already that almost looks like a spark plug. My original thoughts were that it was just screwed in to seal up the screw hole that's there so maybe this is the nipple that your talking about?
No. On RB20 turbo it is a small brass hose barb coming off a boss on the front of the compressor housing. The boss is there on RB25 turbos, but it is not drilled and the barb is obviously not there. On RB25s they fitted the tapping onto the intercooler pipe. It won't be on your pipework as standard. If you have something it will be because someone added, perhaps for a different boost controller iinstallation.
The hose is only 6mm, or possibly even 4mm ID. The hose (stock) goes direct from the hose barb to the wastegate actuator. If a boost controller is installed then it goes via the boost controller before heading to the actuator.
  • Like 1
Also I have been told to install that nipple closest to the turbo as possible(or there abouts) for an accurate WG actuator reaction. So in between the turbo outlet and intercooler or 'the hot pipes'
  • Like 1
My opinion is you should really get a tune done if you plan to run more boost than say 10 psi on the 25 turbo on a rb20. Im not up to date with pricing on Nistune boards but is the $990 you stated earlier on the Nistune board installed + tuned? Im guessing it is.???
my suggestion to you is try and find some 444cc standard GTR injectors which come up in the F/S section all the time. Im pretty sure there a direct bolt in, although you may also need the GTR resistor pack. Another member can confirm??? Get the nistune installed and tuned and enjoy. Getting it tuned will make a reasonable difference to power/torque/drivabilitly/engine longertivity and overall better fuel consumption as has been stated.
I could say more but out of time have to go back to work.
Josh
  • Like 1
I remember a forum member name CEFF13 or something similar had pre-made safe tunes (pretty rich and ignition wasn't too advance) for RB20DET with usual bolt ons and a RB25DET turbo for like $150 delivered, including the IC socket etc...
All you needed to do was desolder your old chip and pop in the new one.
I used one back in the days and managed 180 ish kWs at a dyno day.
  • Like 1
yeah okay.. I guess the only thing I can do right now is install the 25 turbo..
Next track night (yes its a track car) is next friday on the 22nd. So I might attempt the installation the following week.
Ill post results of installation.
I also found out yesterday that my 20 turbo elbow doesn't fit my 25 turbo.... Swear I read somewhere they were the same size??? I found the 20 elbow was marginally smaller....
Edited by Even_Flow
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
