discopotato03 Posted November 13, 2013 Share Posted November 13, 2013 (edited) From people who have made bell mouthed dumps for the GT30 IW outlet what size tube is needed to form the outlet tube welded to the turbos flange plate ? I did look at XR6T dumps but they are on the opposite side of the engine with the gates outlet under the main one rather than above it like it is low mounted on an RB . Here is a link to Best Mufflers and a few pics of what they do for XR6Ts . http://www.bestmufflers.com/Information/Custom%20Systems/custom_exhaust_system_ford_xr6_6cyl_Dyno_Results.htm Cheers Adrian . Edited November 13, 2013 by discopotato03 Link to comment https://www.sau.com.au/forums/topic/434948-gt30-iw-dump-dimension-plz/ Share on other sites More sharing options...
scotty nm35 Posted November 13, 2013 Share Posted November 13, 2013 3 inch pipe, cut up the sides and hand work to suit the flange, then weld in little triangles to cover the hole. Unless you want to run 4 inch? Edit: Here is one of my first custom dumps (3.5 inch) I did for a GT35 on an Aristo, it may give you some ideas. My welding has improved in the last 4 years. Link to comment https://www.sau.com.au/forums/topic/434948-gt30-iw-dump-dimension-plz/#findComment-7106341 Share on other sites More sharing options...
