Hey guys I have been on this page for a little while but only used it for a reference sort of thing. But now I thought I would try my luck asking a question. I recently got my 33 gtst tuned and it has a flat spot in power curve. I basically just want to see if someone has had a similar problem and what they did to resolve it.
Mods are.
•Haltech platinum pro plugin.
•Hypergear atr43g3 on standard exh mani
•Nismo 740cc injectors
•Ebay intercooler kit
•3" bellmouth single piece dump pipe to 3" delete pipe and steps up to 4" before rear muffler.
•Standard plenum
•3" intake to pod filter and 2.5" cooler piping.
•Tomei fpr
Car makes 255.7rwkw on 20psi with bp98 which seems low compared to other peoples results.
Have checked for boost leaks with none found.
Tuner said that he thinks restriction is exhaust manifold but have heard of standard ones still getting 300kw etc.
Has anyone had something similar?
Regards Spencer
https://www.sau.com.au/forums/topic/434952-flat-spot-in-power-curve/
Na I didnt drop the exhaust because I was pretty confident it wasn't a restriction at the time. Might do it once I get it back on the dyno after I change induction pipe to 4" and maybe see if there is a pressure drop through intercooler
I have seen over 400kw through a 3 inch intake too, infact the 430kw 33 had a Z32 afm... No point going bigger than the AFM unless you ditch it and go MAP sensor.
Just looking at the graph, it seems you are missing a chunk of boost in the midrange, did you get a boost plot by chance?
That is a whack result. Scottynm35 has seen huge power through stock mani, Not sure what your issue is, many things to check but I hope you can get it sorted out.
E85 is a hell of a thing. Can't compare a car which is tuned on petrol with one which is tuned on ethanol - the nastiness which is the stock manifold gets covered up a bit if using a very knock resistant fuel.
E85 coveres up 200kw... Yeh right. :P
Anyway, 250 isn't it's limit surely, not to mention, where is his midrange? It either has no boost in the midrange, or no timing, probably due to a big restriction somewhere. Cam timing?
Did I mention my closed 1.5 inch Varex exhaust makes more than 250? ;)
I wasn't referring to the 250kw thing specifically - so much as how ridiculous comparing a big turbo high octane combination with a small turbo pump gas setup... there is an issue there, but mentioning a 400+kw ethanol setup is probably not being helpful for perspective.
It proves the standard manifold can flow a lot more than the power he is making. Many people (myself included) have made much more than 250kw through standard manifolds on 98. Why argue against scottys valid point that in this case manifold flow is not the restriction?
Because I was bored at home with manflu and brain wasn't working very well - my bad! Forgot I even posted that. There is clearly an issue that isn't the exhaust manifold causing it.
post-104841-0-53226600-1384589445_thumb.jpgI changed my induction pipe to solid 4 inch yesterday instead of it stepping down to 3 inch. Tuner is going to print me out a picture of boost plot so will show that when I get it. Also going to change actuator to 14psi and run an eboost street to have high and low boost and get retuned.
Here is a photo of my timing map
That timing map is pretty average. Looks like a huge reduction at around 5krpm-20psi drops like 3-5deg then back up at 6k. I'd imagine that'd feel pretty flat through there.
Did the tuner say anything about the engine wanting to knock?
    • My goals for it atm are to get it registered, respray and some mild power gains eventually... I picked up the car from an elderly gentleman near the border of NSW and VIC, its honestly a bit rough and looks like its been driven on a farm (because there was so much dirt underneath). Last week I dropped the subframe and emptied the old fuel out + added a new fuel pump (think the old one went bad from old fuel). Now I'm onto fixing a coolant leak at the rear of the engine + adding a new radiator as the old one is corroded. After that i have a new bumper, coils (as the old were leaking) and lots more
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
    • Came here to say, put all the wiring from the new motor and gearbox in that you can, then throw the stock ECUs in the bin, and get an aftermarket ECU. Should be pretty easy if you can use a multimeter and read a wiring diagram to then use a PNP aftermarket ECU to suit the motors wiring loom, and make the minimal changes you will to get it to work in with the body loom (If any). This will mean you can very easily circumvent/bypass the Park/Neutral start disable switch, and get everything running really easy!
    • If the roof is dual skinned the whole way, IE, there's a "top" metal piece, and a "bottom" metal piece, to slow it down as much as you practically can, you should be able to get an attachment for a spray can/your spray gun, where it is a long, thin flexible hose, and when you're "spraying" it is spraying it in every direction possible. The I'd get that, and feed it through the roof as much and as far as you can. It's basically like fish oiling the car, but you're soaking it in rust converter. Then do the fix like Murray has described having cleaned up the existing metal as much as you humanly can. I'd also throw as much rust converter on that exposed metal before putting the fibreglass/metal filler over everything.   As for welding a replacement in. I've owned my own MIG welder for about 10 years. I've also worked in an industry doing MIG welding for a job for about 3 months dead straight, and we were doing 11.5 hour work days 5 days a week, plus a Saturday 6 hour day. (I then moved over to running the massive CNC plasma as I could understand the technology, and work with the main guy out there). I also f**k around with my welders a bit at home. So what I'm saying here is, I've probably got more hours on a MIG gun than you'll manage to get under your sleeve doing home sorts of jobs over the next 5 years. I also have an ACDC TIG that I got myself a year or two back. I've got a short amount of experience on the TIG only. My home MIG is also presently setup for doing thin sheet metal. Unless I didn't care about how that roof looked, and I just wanted a functional metal roof, and it being out of alignment, warped, and bowed, I would NOT attempt a roof replacement UNLESS I could do it as a whole panel like Murray described where the spot welds were.  Welding has this REALLY annoying thing, where if you want something to be perfectly square, unless you can clamp that thing to damn perfection (Welding fixture table), it is NOT going to be square, so you start to learn, the type of metal you're working with, how thick it is etc, and weld in VERY specific ways, and by knowing how YOU are as a welder, so that as the welds cool, the metal work pulls itself into place. If you want to see some cool tricky shit done, Bennets Customs is an Aussie guy, and he mentions a guy a lot call "Kyle", who is from "Make It Kustom". Watch some of their welding videos, especially on sheet metal. You can use the welder to shrink the steel in, and you can also use the welder to stretch the panel out. When you have the skill level that I have, you can shrink the metal in and out... But never on purpose like those two guys do. You just manage to f**k it all up. Then I smack it around with a hammer till it sits lower than I will want it too, then I shove filler on top and then pray to deitys that I can sand it into some form of sane shape that doesn't look like a dog has taken a shit, after eating a tonne of pumice stone... I'm all for DIY, and for learning, and please, feel free to give it a go, but be aware, you need to live with the consequences of how time consuming it is to do, AND that it's going to look no where near as good as what you can make it look with just some filler now. Oh AND, even once you replace it, it's like to still rust away again eventually, because you'll have missed putting primer and paint on some part of the newly welded in sheet metal, or against part of the existing metal you couldn't get to...   Oh, and to weld all that in, you will need to pull the window out, and strip at least the roof and A Pillars of interior trim and wiring. You'll then need things like the big fire proof/weld spatter proof mats to lay down, OR you'll end up needing to strip the ENTIRE interior to avoid sending it all up in a ball of flames. If you want to see how annoying sheet metal is to weld, head to bunnings, buy there 600x600 1.6mm mild steel (Not GAL!) sheet, and cut a few pieces, and try and weld them together. Then understand, 1.6mm sheet is nearly 50 to 100% THICKER than the cars sheet metal.   The photos I posted before, I'm replacing with 1.2mm thick mild sheet, and it's very easy to blow through both the original steel (Especially if I hit an area that should have probably been cut out a bit more) or straight through the new sheet metal. And I'm doing the floor, which can be hidden easily, and doesn't matter how pretty I make it, as long as it's damn strong! I'm also doing it in a 4WD, that has seen many off road trails, and doesn't need to look that pretty ever
