Hey guys I have been on this page for a little while but only used it for a reference sort of thing. But now I thought I would try my luck asking a question. I recently got my 33 gtst tuned and it has a flat spot in power curve. I basically just want to see if someone has had a similar problem and what they did to resolve it.
Mods are.
•Haltech platinum pro plugin.
•Hypergear atr43g3 on standard exh mani
•Nismo 740cc injectors
•Ebay intercooler kit
•3" bellmouth single piece dump pipe to 3" delete pipe and steps up to 4" before rear muffler.
•Standard plenum
•3" intake to pod filter and 2.5" cooler piping.
•Tomei fpr
Car makes 255.7rwkw on 20psi with bp98 which seems low compared to other peoples results.
Have checked for boost leaks with none found.
Tuner said that he thinks restriction is exhaust manifold but have heard of standard ones still getting 300kw etc.
Has anyone had something similar?
Regards Spencer
https://www.sau.com.au/forums/topic/434952-flat-spot-in-power-curve/
Na I didnt drop the exhaust because I was pretty confident it wasn't a restriction at the time. Might do it once I get it back on the dyno after I change induction pipe to 4" and maybe see if there is a pressure drop through intercooler
I have seen over 400kw through a 3 inch intake too, infact the 430kw 33 had a Z32 afm... No point going bigger than the AFM unless you ditch it and go MAP sensor.
Just looking at the graph, it seems you are missing a chunk of boost in the midrange, did you get a boost plot by chance?
That is a whack result. Scottynm35 has seen huge power through stock mani, Not sure what your issue is, many things to check but I hope you can get it sorted out.
E85 is a hell of a thing. Can't compare a car which is tuned on petrol with one which is tuned on ethanol - the nastiness which is the stock manifold gets covered up a bit if using a very knock resistant fuel.
E85 coveres up 200kw... Yeh right. :P
Anyway, 250 isn't it's limit surely, not to mention, where is his midrange? It either has no boost in the midrange, or no timing, probably due to a big restriction somewhere. Cam timing?
Did I mention my closed 1.5 inch Varex exhaust makes more than 250? ;)
I wasn't referring to the 250kw thing specifically - so much as how ridiculous comparing a big turbo high octane combination with a small turbo pump gas setup... there is an issue there, but mentioning a 400+kw ethanol setup is probably not being helpful for perspective.
It proves the standard manifold can flow a lot more than the power he is making. Many people (myself included) have made much more than 250kw through standard manifolds on 98. Why argue against scottys valid point that in this case manifold flow is not the restriction?
Because I was bored at home with manflu and brain wasn't working very well - my bad! Forgot I even posted that. There is clearly an issue that isn't the exhaust manifold causing it.
post-104841-0-53226600-1384589445_thumb.jpgI changed my induction pipe to solid 4 inch yesterday instead of it stepping down to 3 inch. Tuner is going to print me out a picture of boost plot so will show that when I get it. Also going to change actuator to 14psi and run an eboost street to have high and low boost and get retuned.
Here is a photo of my timing map
That timing map is pretty average. Looks like a huge reduction at around 5krpm-20psi drops like 3-5deg then back up at 6k. I'd imagine that'd feel pretty flat through there.
Did the tuner say anything about the engine wanting to knock?
    • Already looked at a few prior to getting the MX5, really nice car, had all the mod cons, but I wasn't really sold on the new "look" I did miss my 2017 Limited, and I personally prefer the "look" of the older car over the new model, but, when pondering I kept going back looking at MX5's But it was same same for the new ND's, I wasn't sold on the new "look", especially the RF with its weird roof, which only half goes down, like a targa top sort of thing As I stated before, I did look at NC's, but the cars I looked at were PRHT's, but I didn't like their roof line "look" of the PRHT, until I saw the soft top version, (someone on SAU posted a for sale ad for one with a soft top that caught my attention, you can blame them for my choice.....🤣) and.... that old style detachable hard tops were available for them, which keeps the old MX5 more smoother flowing roof line, and the more rounded body style, similar to the NA-NB, to me, the arse end of the ND looks to "modern" Much like how I prefer the NC1 front bar, over the later models How long will I keep this car for is unknown, but currently, there's nothing else out there that "floats my boat" for a small, fun, little "sports car", that I can play with and enjoy looking at and driving But, who knows what the future holds, and going off current new car styling, if I replace it, it will be a older model something something
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
