Nsw Rms Light Vehicles Modification Guide Updated 8/11/2013
Can someone delete the spam post and sticky this thread? Is a great resource
I deleted the posts, hopefully the IPs get blocked soon too. It's not just the NSW section, either.
Also, topic "stickied" for easier reference.
What is this spam shit that is getting through the forums lately? Why SAU!! It is grinding my gears. Mods need to do something about the signing up / privledges to post.
Yeah, as above, I've deleted it. I'm only a Moderator, so that's as much as I can do. I have let the Admins know that the users and/or IP addresses need to be blocked.
In the mean time, I need to get me some Ugg boots! :P
  • Like 1
Theres some interesting 'very grey' areas there. I'd suggest to anyone with a vehicle modified within the criteria to keep a copy in their car, to show anyone inspecting the car on the roadside that certain items they think are defective are not (you probably won't win, it'll just make them more angry - especially if you have a rego inspectors ticket & they only have a badge).
I think they've tried so hard to make it easy to read/understand that they've missed some critical detail.
eg; An engine that is not of an original family of engine for the series of models, or any engine more than 20% larger than the largest original optional engine for that series.
Does that mean I can replace my 1JZ with a 2JZ? (20% increase in capacity)
I'm pretty sure it doesn't but it kind of sounds like I can??
Example not requiring certification:
• Replacement of a 2.0 litre engine with an engine of 2.4 litres capacity or less and from the same vehicle series.
Interesting - that'd preclude swapping my 4G94 with a 4G69 then - two Lancer VRX from 2004, but one's a CH and the other CG, so no swapping I guess.
...Not that I'd spend money on doing that, though.
edit:: but it sounds like swapping it for a 2.0 4g93 is a-okay with certification? helloooooooo evo engine
So swapping and rb25det with an rb26det still requires a certificate?
The only one I'm going to have a problem with (since I got defected the other week for it) are aftermarket seats
I've got bride seats + rails in my 34
Would I have any problems getting them engineered?
Fitting of seats to non-original seat anchorages.
Example requiring certification:
Fitting seats using anchorages not originally supplied by the manufacturer.
seats dont meet ADR however no modifications to anchorages have been made so engineering will be a breeze! i had mind noted on my report aswell
Even though the rails are brides?
Who did you go through for the engineering cert?
ill have to check my cert when i get home. Arsed if i remember
yeah rails will be fine given they bolt all to the factory location using factory mounts etc
  • 2 years later...
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
