Nsw Rms Light Vehicles Modification Guide Updated 8/11/2013
Can someone delete the spam post and sticky this thread? Is a great resource
I deleted the posts, hopefully the IPs get blocked soon too. It's not just the NSW section, either.
Also, topic "stickied" for easier reference.
What is this spam shit that is getting through the forums lately? Why SAU!! It is grinding my gears. Mods need to do something about the signing up / privledges to post.
Yeah, as above, I've deleted it. I'm only a Moderator, so that's as much as I can do. I have let the Admins know that the users and/or IP addresses need to be blocked.
In the mean time, I need to get me some Ugg boots! :P
  • Like 1
Theres some interesting 'very grey' areas there. I'd suggest to anyone with a vehicle modified within the criteria to keep a copy in their car, to show anyone inspecting the car on the roadside that certain items they think are defective are not (you probably won't win, it'll just make them more angry - especially if you have a rego inspectors ticket & they only have a badge).
I think they've tried so hard to make it easy to read/understand that they've missed some critical detail.
eg; An engine that is not of an original family of engine for the series of models, or any engine more than 20% larger than the largest original optional engine for that series.
Does that mean I can replace my 1JZ with a 2JZ? (20% increase in capacity)
I'm pretty sure it doesn't but it kind of sounds like I can??
Example not requiring certification:
• Replacement of a 2.0 litre engine with an engine of 2.4 litres capacity or less and from the same vehicle series.
Interesting - that'd preclude swapping my 4G94 with a 4G69 then - two Lancer VRX from 2004, but one's a CH and the other CG, so no swapping I guess.
...Not that I'd spend money on doing that, though.
edit:: but it sounds like swapping it for a 2.0 4g93 is a-okay with certification? helloooooooo evo engine
So swapping and rb25det with an rb26det still requires a certificate?
The only one I'm going to have a problem with (since I got defected the other week for it) are aftermarket seats
I've got bride seats + rails in my 34
Would I have any problems getting them engineered?
Fitting of seats to non-original seat anchorages.
Example requiring certification:
Fitting seats using anchorages not originally supplied by the manufacturer.
seats dont meet ADR however no modifications to anchorages have been made so engineering will be a breeze! i had mind noted on my report aswell
Even though the rails are brides?
Who did you go through for the engineering cert?
ill have to check my cert when i get home. Arsed if i remember
yeah rails will be fine given they bolt all to the factory location using factory mounts etc
  • 2 years later...
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
