Hi, if anyone is keen on one of these rare Bad boys let me know.
These are a race specific from Garrett and the public don't usually get their hands on them,
The retail of one turbo is $13000
$2500 takes it and the turbo is brand new, i am ordering a set for my self atm so if anyone wants to save on shipping let me know.
The turbos are super light, about 8 pounds per turbo.
Specs and pics as follows.
Titanium comp wheel
Titanium Turbine wheel
Titanium Turbo shaft
Special 1-off race bearing design
Magnesium Comp cover
Stainless steel V-Band rear housing (for quick Turbo change or a/r change), these are similar to Tial v-band housing but they are made by Garrett's racing devision.
Compressor OD ~70mm
Turbine OD ~60mm
PM or phone 0431113255.
https://www.sau.com.au/forums/topic/434979-garret-racing-tr30r-turbo/
could you enlighten me as to the nature of the special 1-off race bearing design?
also could you post a location too.
They bearing design is race specific, internal has adapters to change different wheels sizes and shafts, inside is made from titanium, i would call it something like a triple ball-bearing, they are rebuild-able and last for seasons on race cars with antilag not even needing a rebuild.
Located in WA.
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
