how about some figures on the pump..... in tank bosch 044 pumps are cheaper installed and we all know what they can flow...SHEDLOADS.
what kind of performer is the HKS pump?
well all i can tell you is that this pump flows 280L/H which is 125% better than std as claimed by HKS i have been told that they can support upto 800bhp by some reputable tuners in brisbane... some say the std pump handles 600bhp no probs
and the flow rate does not get affect much by the boost pressure as your o44 pump can... it also has the built in pressure regulator looking thing as the standard pump... and fits in the standard spot with out mod's
it has the same flow rates as the apexi, nismo and all the other brand name pumps but tomei pump with the same flow rate has been recommended to handle upto 1000bhp of fuel. because i never got to use it in my car that is all that i can tell you..
thanks for the info....
I dont all that much about pumps except that alot of people swear by the 044. I am looking at upgrading to an intank pump before the end of next week. I only have the standard pump and i have been told i need atleast 300-320 L/H to keep up with my injector and air flow rates.
Thanks
TG
i don't know if this info will help you but if you need that kind of flow the 044 is not capable of delivering that. i went through all the trouble when i was upgrading my car. without knowing what BHP your trying to achieve i can't comment anymore, the standard pump will flow easy 500bhp at the motor belive it or not. and in intank form the 044 by it self will do about 600bhp at 1.5 bar pressure with HKS 2540 turbos. that was why i got the HKS pump just to make sure that the pump is not over worked as it was rated at 800bhp. so i think you should find out bit more information about what you really need befor you spend any money.... if you are gonna keep the motor stock bosh 044 or the hks or any other brand name will do but if you are gonna go further it might pay to get a surge tank and maybe run twin 044's
just my suggestion
cheers.
Andrew
engine is not stock and from what you have stated, obviously my car is not running the standard fuel pump in it. My car is making over 420 rwhp which is about 550hp at the engine. Perhaps an 044 would be a step backwards, but i doubt it!
I have seen a car make over the 550 rwhp figure claiming a single bosch 044 fuel pump feeding the rail.
TG
like i said i'm only telling you what i been told by others
and yes i have seen standard pump do 600bhp at the engine and the bosh 044 do 800bhp also but not sure how reliable it is. i have only told you what has been recommed by the manufactures so please don't take offence to what i have told you
i only did it to try and save you some time in researching
like i said it was just some info....
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
    • Yes, a plan for non-action is always my first sort of plan! I'm happy to see what falls out of invision's update. I had been having some thoughts on what to do with this the other day and they all seem to have fled my memory, after various solar panel induced traumas, squeaking suspension sphericals, etc etc, over the last little bit. I'll try and recall what I had in mind and make sure that I put it into print in some form before the Alzheimer's strikes again.
    • The ability to have both a 5500 stall for launching, and a regular lockup for every other scenario is pretty sweet. Does it actually work well like that though in the real world? Would it hold up to track use and otherwise you'd never know you had a stall converter in it? If so, that's awesome
