how about some figures on the pump..... in tank bosch 044 pumps are cheaper installed and we all know what they can flow...SHEDLOADS.
what kind of performer is the HKS pump?
well all i can tell you is that this pump flows 280L/H which is 125% better than std as claimed by HKS i have been told that they can support upto 800bhp by some reputable tuners in brisbane... some say the std pump handles 600bhp no probs
and the flow rate does not get affect much by the boost pressure as your o44 pump can... it also has the built in pressure regulator looking thing as the standard pump... and fits in the standard spot with out mod's
it has the same flow rates as the apexi, nismo and all the other brand name pumps but tomei pump with the same flow rate has been recommended to handle upto 1000bhp of fuel. because i never got to use it in my car that is all that i can tell you..
thanks for the info....
I dont all that much about pumps except that alot of people swear by the 044. I am looking at upgrading to an intank pump before the end of next week. I only have the standard pump and i have been told i need atleast 300-320 L/H to keep up with my injector and air flow rates.
Thanks
TG
i don't know if this info will help you but if you need that kind of flow the 044 is not capable of delivering that. i went through all the trouble when i was upgrading my car. without knowing what BHP your trying to achieve i can't comment anymore, the standard pump will flow easy 500bhp at the motor belive it or not. and in intank form the 044 by it self will do about 600bhp at 1.5 bar pressure with HKS 2540 turbos. that was why i got the HKS pump just to make sure that the pump is not over worked as it was rated at 800bhp. so i think you should find out bit more information about what you really need befor you spend any money.... if you are gonna keep the motor stock bosh 044 or the hks or any other brand name will do but if you are gonna go further it might pay to get a surge tank and maybe run twin 044's
just my suggestion
cheers.
Andrew
engine is not stock and from what you have stated, obviously my car is not running the standard fuel pump in it. My car is making over 420 rwhp which is about 550hp at the engine. Perhaps an 044 would be a step backwards, but i doubt it!
I have seen a car make over the 550 rwhp figure claiming a single bosch 044 fuel pump feeding the rail.
TG
like i said i'm only telling you what i been told by others
and yes i have seen standard pump do 600bhp at the engine and the bosh 044 do 800bhp also but not sure how reliable it is. i have only told you what has been recommed by the manufactures so please don't take offence to what i have told you
i only did it to try and save you some time in researching
like i said it was just some info....
