Just looking for a filter and gasket for my S1 stagea, and I am wondering whether any RE4R01A service kit will do, or do some cars use different sumps and different shaped filters etc?
eg
http://www.ebay.com.au/itm/AUTOMATIC-TRANSMISSION-SERVICE-KIT-NISSIAN-PATHFINDER-RE4R01A-AUTO-TRANS-GEARBOX-/121203320102?pt=AU_Car_Parts_Accessories&hash=item1c3847e526
https://www.sau.com.au/forums/topic/435030-auto-service-kit/
If I go to supercheap (or heaven forbid nissan) and ask for other vehicle models that may fit, what would be some options? Are there any differences in 2wd and 4wd ones (like a skyline gtst auto)?
Supercheap won't be able to tell you what fits what unless they have details of what model car that transmission is in or the transmission model itself(which is very unreliable as it's a keyword search).
They can also look up imports so you might be lucky otherwise find out which other ADM vehicle the trans is delivered in and use that.
Best to call them first, just give them car details (make, model, year and engine capacity).
Edited by M35woah
What is wrong with some gasket maker? I just use high temp silicone for the sump.
The filter is re-usable so I can't see a point in buying a kit. Probably better off sticking a shift kit in there when you clean the filter...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
