Selling standard turbo that i took off an R34 i stripped. Only has the normal amount of shaft play that these have standard, it is overall in great condition and working great. I have worked at Nizpro Turbocharging so i know a little bit about turbochargers and im happy to stand by this turbo as a bolt on replacement for a blown standard turbo. Has Nylon comp wheel to increase boost response.
Comes with all lines still attached and the bracket and oem heat shield, banjo bolts and oem gaskets (still usable)
Suit someone that has an aftermarket turbo set-up and needs to go back to standard to clear defect.
$300 FIRM as i know its a good unit and your buying from a mechanic with turbo experience so you get piece of mind :)
Located in S.E suburbs of Vic but happy to help with postage at your expense.
Have more photos of turbine wheel and comp wheel if you would like them msg'd to you just ask
http://imageshack.com/a/img132/9718/np55.jpg
http://imageshack.com/a/img203/2166/w65f.jpg
http://imageshack.com/a/img11/4840/8azy.jpg
Chris
041281three55one
  • 9 months later...
  • 1 month later...
