Yeah I think the best bet is to get it high flowed (steel wheels) and then you wont have to worry. Run stock boost no issue
Then when you want more power just get the supporting mods and wind the boost up. Cheaper than constantly buying replacement stock turbos
I know its not really solving the original problem. But still a good idea
  • Replies 51
Hi Stao.....read my post. There are ways it could happen. Anything that causes that signal to be lower (where it is sourced from) than the turbo's outlet pressure will permit it to work too hard.
Maybe....but what happens when you have that is that the turbo spins up and gets hot, then the bearings gall and sieze and the sudden shock would be what shakes the turbine loose. But I wouldn't expect the shaft to spin nicely afterwards, and it sounds like yours still have been.
The rear wheel doesn't spin after they blow up, all 3 turbos the rear wheel has been f**ked and the front wheel still spins!! One of the turbos found some of the rear wheel in my exhaust (cat)
Okay thanks for that input guys, if a steel wheel turbo is what's going to fix this problem looks like that's what I'm gonna do, I'm also going to check the oil flow but other then that it's got me stumped. So if anyone could recommend someone who does decent turbo rebuilds that would be greatly appreciated as is all of your input! Thanks
Check out the latest results from our current 21U std R33 high flowed turbocharger on the last few pages. They are capable of doing factory alike response of 260rwkws+ on P98 and have done 320rwkws with E85. Cost only $850 now with oil line, and that has been welly track proven.
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/
yeah just go with hypergear, the new 21U profile is pretty damn good. someone made over 320 kw on e85 with it which is amazing for the stock r33 turbo housings. other than that it performs well as a stock replacement with a bit more oomph. responsiveness is about the same as a stockker because the stockers are just old now anyway.
edit: forgot to mention its cheaper than the competition too
Edited by Blackkers
The wheels live on a common shaft. If the comp wheel will spin, then the shaft is free to turn, and if the turbine was still there (which it's not because it's dead) it would then still spin too.
Thanks for all your help everyone, it was a block in the oil line! It's been fixed and I put a steel wheel turbo on the car aswell
Good work finding it. For our benefit how did you find it? by checking flow out of turbo drain first, or just whipping off oil feed line?
I unbolted the oil line from the turbo put a bucket underneath and started the car to check flow and there was little to none (it would have been messy if there was) I got a braided line and done the same thing and I got a few hundred ml in seconds. So not sure how or why but the line was blocked or something.. New turbo has been on for a solid 24 hours, feels and sounds a lot better already. Very relieved so far!
The line is blocked by the banjo bolt into the block usually. They have a .9mm restrictor built in don't they?
The VQ does anyway, it actually runs 3 restrictors due to high oil pressure.
its an oil line that is 15-20 yrs old, and with the restrictors they have in them they will undoubtedly gather deposits and block over such a period of time.
you are sorted for boost and tune now :)
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
    • Yeah, that and throwing away opened, part used, closed back up bottles has got to be bullshit. Brake fluid sits in not-very-well sealed master cylinder reservoirs for literal years and keeps working (albeit we know we should flush it every couple of years - it actually still works). Anything kept in a bottle in the shed with a tightly capped lid has got to be a million times better than what has been in the car for the same length of time.
    • Wait, they're claiming UNOPENED fluid has a shelf life of only 18 months?
    • The plan is to get it out of the shed. The reality may fall some way short. But hope is as cheap as despair as they say. Will go a wide band I think. The coils are ok so maybe I’ll miss the $1500 on the R35 coils etc. Im still on the fence about a trigger kit. The HKS one looks nice ($1k) - not sure how it works with the Link or if Link prefer something else. Oil pressure is fine so I’m not that concerned there. Fuel pressure I’ll have a think about. The IAT got changed for the Link anyway as the old RB26 ones were really slow reacting and pretty poor. The Power FC just worked. Wasn’t terribly refined but it just worked. Probably made a mistake replacing it really. E85 isn’t available locally - it is 100+ kms away which puts it in the too hard basket. Lastly I understand Tunecorp in Perth are pretty good so was probably going there.   As for turbos is there are new age -5 drop in replacement? Turbos have come a long way in 20 years, everyone is big single which is fair enough but I prefer the old school complication of twins. Wasn’t chasing more power (well, not much more) but more efficiency would be ok.
    • I thought I'd share this....the shell is non genuine but they found or built a lot of the genuine parts. Plus, it is by far the best colour scheme of those years, the winfield once was particularly shit https://www.v8sleuth.com.au/written-off-inaugural-godzilla-recreated/
