Well mitch if your looking at keeping your car for the long term then a zorst & set of extractors r a good start with a hiflow cat converter + with a little more power u might want to look into a lowering kit shockys & springs sway bars +
watch the rear control arm bushings they tend to wear out & split & you get free movement of the diff.
Ball joints/control arms on the front are another area to watch/check too if the car has been driven hard the ball joint shockets will have free play around the ball joint making it look like u have floged ball joints but is really the arms.
How ever the arms can be sorted with out new items being sorced by way of welding the ball joints in place I would not recommend this being done if you have the money get a set or one from the wrecker
Hope that helps mate
:rant: Mike
https://www.sau.com.au/forums/topic/43513-r31-first-car/#findComment-890008
Hi mitch94.. fancy bumping into you here :)
I'm the one that's been advising you on mods (and wheels) on the SVD forums :(
As far as "cheap" mods go, there are a lot around... but free ones, well.... air box mod is about the only "free" mod, provided you can find the bits you need for it.
(One tricky way of doing it is cutting a hole in the top of the air box, then swivelling it around to face forward)
Even something as simple as advancing the timing will probably end up costing you money, chances are good that if you advance the timing, it will cause the car to ping, and you will need to run premium instead of regular fuel.
The laws of physics say that "for every action, there is an equal but opposite re-action"
......in the land of cars, all that means is "if you want power, it's going to cost" :(
https://www.sau.com.au/forums/topic/43513-r31-first-car/#findComment-890709
cheap to some can be $5 to $5000, and cheap can cost more in the long run, basics are the best,air induction,leads,plugs,extractors,exhaust or maybe handling shocks,springs, sway bars even a good set of tyres can make a world of difference! it all will cost $$$
https://www.sau.com.au/forums/topic/43513-r31-first-car/#findComment-892098
extractors are a nice upgrade.. and you can get them nice and cheaply 2nd hand. Just the other day i sold rsx84 above a set for $100, so that is a fairly cheap upgrade :)
My old R31 didn't have extractors or exhaust system, my current one does, and sounds and goes a noticeable amount better. Mainly the sound :(
https://www.sau.com.au/forums/topic/43513-r31-first-car/#findComment-897800
put a manual gearbox in (seriously) $1000 on the cheap
Go to 16x7 or 16x8 or 17x7 wheels with good tyres. $500 - $5000
Good brake pads, good fluid $300 +
Suspension - $1000 - $5000 (lowerd springs, aftermarket shocks, swaybars, strut brace, strut tops)
Headwork, cam, chipped ecu - $2000
Depends what you mean by faster. If you mean "a tiny tiny bit faster in a straight line, which youll hardly notice" the do the exhaust, intake, wind the timing up. If you want to notice the increase but still be slow, do the head cam and chip.
If you want to make the car safer, faster through corners, on mountain runs, in time trials, and heaps more fun to drive - do the brakes and suspension. If you can afford to do brakes and suspension, and still have some $ to make it manual and up the power a little bit, do it.
Ive gone down the brakes/suspension path, with exhaust/intake/timing, and I am the quickest @ the Mt Cotton Driver training Centre time trials, mainly against R33 GTS-t's.
Leave the brakes and suspension stock, and no matter what you do to the motor, the car is still going to suck unless you are going straight ahead.
https://www.sau.com.au/forums/topic/43513-r31-first-car/#findComment-908440
Aussie four door r31's have a tendancy to handle like a boat. Suspension is one thing I recommend. Extractors, Zorst and Pod do well. Keep your ignition system in good nic and it'll definately move better.
My r31 sits real high at the moment and handles like a Toyota Landcruiser. have to slow down for every corner. but it does help when i want to drive over things!
-jim
https://www.sau.com.au/forums/topic/43513-r31-first-car/#findComment-908492
after about the 6th item it starts getting more expensive. A 2 1/2 exhaust might drone abit so you might have to get a resonator. Your going to have to spend some money to get good power out of an rb30e.
-K&N pod filter with CAI
-mandril bent 2 1/2 exhaust + high flow cat ( your old cat is probably dead )
-extractors ( you can get some 2nd hand for as little as $100 ) Pacemaker ones are one of the better brand extractors that you can get.
-advance the timing 20 degrees BTDC
-XF throttle body
-4.11 diff ratio
-Different cam - Nizpro= cam/lifters $770 ( might need a chip for the ecu )
-head port and polish - i think around $400
https://www.sau.com.au/forums/topic/43513-r31-first-car/#findComment-918659
    • Good tips, I like it! 😂😂 My wife is a LOT more frugal than me so it's only me we need to worry about! A splurge to her is buying 2 pairs of socks in one visit at Kmart!
    • Haha, the appropriate response to the question "Is this new?" is "I've had this for a while.". With the unspoken small print that a while may be the time since this morning or five years ago   And to be fair I learned that from the best, i.e. my wife. Because it goes both ways.
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
