Dan_J Posted November 19, 2013 Share Posted November 19, 2013 (edited) rb20 30 row cooler with 10/40 racing penrite , highest i've seen is 120 generally cool down lap on 100c. currently added a 2nd oil cooler and dont see temps above 70c..... Edited November 19, 2013 by Dan_J Link to comment https://www.sau.com.au/forums/topic/435145-oil-temp-on-track/page/2/#findComment-7113456 Share on other sites More sharing options...
PN-Mad Posted November 19, 2013 Share Posted November 19, 2013 Suppose I'll chime in SR20 290kw 19 row cooler, ducted sorta povo style. GW synx6000 5-40 Highest temp I've seen is 105 degrees after a full on 15 min session at Wakefield. Water and oil will sit dead on 70 on the freeway all day. Link to comment https://www.sau.com.au/forums/topic/435145-oil-temp-on-track/page/2/#findComment-7113476 Share on other sites More sharing options...
dan.1337 Posted November 19, 2013 Share Posted November 19, 2013 I'm running Penrite 10W-50. Bought on sale from Supercheap for $40/5L. Link to comment https://www.sau.com.au/forums/topic/435145-oil-temp-on-track/page/2/#findComment-7113578 Share on other sites More sharing options...
scotty nm35 Posted November 19, 2013 Share Posted November 19, 2013 with a cooler that big I'd be looking long and hard at it, then tell someone to fix it ! I do all my own spanner work, no-one is touching this VQ but me. As I was measuring the temp into the cooler, inside the 12an lines, I figured the thermostat was wide open. I should check it's operation again just to make sure, but it holds 82 degrees pretty constantly on the road. I think the oil is just picking up the heat from the pistons and transferring it away. To lower the piston temp I should just run less boost at the track I guess, but where's the fun in that... It's a great feeling blasting past GTR's at 40psi. Link to comment https://www.sau.com.au/forums/topic/435145-oil-temp-on-track/page/2/#findComment-7114009 Share on other sites More sharing options...
Dose Pipe Sutututu Posted November 19, 2013 Share Posted November 19, 2013 are you guys all running thermostats? (I know it's a little pointless on the track) but are there any real downsides? Link to comment https://www.sau.com.au/forums/topic/435145-oil-temp-on-track/page/2/#findComment-7114102 Share on other sites More sharing options...
Aazzy Posted November 20, 2013 Author Share Posted November 20, 2013 Found that the air temp sensor was cutting ignition as the air was too hot. Oil temp wasn't my issue at all. It doesnt have a gauge for plenum air temp. (didn't think i really needed it) it may have just been that it was a hot day and was right up the back of an elfin that weighed about 650kgs, when I'm still pushing 1250kgs around. Those things are so god dam quick out of the corners. Link to comment https://www.sau.com.au/forums/topic/435145-oil-temp-on-track/page/2/#findComment-7115472 Share on other sites More sharing options...
Aazzy Posted November 20, 2013 Author Share Posted November 20, 2013 Off topic here but why is it that when I type G.O.D. As one word it comes out as rajab? 2 Link to comment https://www.sau.com.au/forums/topic/435145-oil-temp-on-track/page/2/#findComment-7115475 Share on other sites More sharing options...
Leroy Peterson Posted November 20, 2013 Share Posted November 20, 2013 are you guys all running thermostats? (I know it's a little pointless on the track) but are there any real downsides? just for warming up the car i guess. If its track-only you'd be alright. But street driven you'd have to give it a while to warm up SR20 PWR core radiotor (not sure how big), oil cooler running 10W40 royal purple and hottest I ever got it was a 30 degree day at Winton hit like 115 or near abouts. Will be testing out a 5W40 Motul racing oil when new engine is run-in, then going to try the Penrite and if there isnt much of a difference will switch to Penrite. Link to comment https://www.sau.com.au/forums/topic/435145-oil-temp-on-track/page/2/#findComment-7115606 Share on other sites More sharing options...
niZmO_Man Posted November 20, 2013 Share Posted November 20, 2013 Off topic here but why is it that when I type G.O.D. As one word it comes out as rajab?Rajab is our son of rajab and saviour Link to comment https://www.sau.com.au/forums/topic/435145-oil-temp-on-track/page/2/#findComment-7115784 Share on other sites More sharing options...
fatz Posted November 20, 2013 Share Posted November 20, 2013 i have been thinking about my recent oil temp rises after reading this thread i recon my thermostat is sticking for some reason, can be the only reason for seeing 130 degrees in 3 laps last time out as its never gone above 110 even after 20 laps previously Link to comment https://www.sau.com.au/forums/topic/435145-oil-temp-on-track/page/2/#findComment-7115789 Share on other sites More sharing options...
C4a0s Posted November 20, 2013 Share Posted November 20, 2013 are you guys all running thermostats? (I know it's a little pointless on the track) but are there any real downsides? not using any thermostat... yeah as what Leroy mentioned... its purely for warming up the car.. all u need to be mindful of after taking it out ...is to let car warm up (takes a while more) before putting the pedal to the metal. on track, the thermostat would probably hamper flow. worst case scenario... if it jams, temps be sky high... Link to comment https://www.sau.com.au/forums/topic/435145-oil-temp-on-track/page/2/#findComment-7115823 Share on other sites More sharing options...
C4a0s Posted November 20, 2013 Share Posted November 20, 2013 i have been thinking about my recent oil temp rises after reading this thread i recon my thermostat is sticking for some reason, can be the only reason for seeing 130 degrees in 3 laps last time out as its never gone above 110 even after 20 laps previously it could be... try taking it out and see how it goes Link to comment https://www.sau.com.au/forums/topic/435145-oil-temp-on-track/page/2/#findComment-7115824 Share on other sites More sharing options...
XKLABA Posted November 21, 2013 Share Posted November 21, 2013 I do all my own spanner work, no-one is touching this VQ but me. As I was measuring the temp into the cooler, inside the 12an lines, I figured the thermostat was wide open. I should check it's operation again just to make sure, but it holds 82 degrees pretty constantly on the road. I think the oil is just picking up the heat from the pistons and transferring it away. To lower the piston temp I should just run less boost at the track I guess, but where's the fun in that... It's a great feeling blasting past GTR's at 40psi. Haha yeah me to, a lesson I learnt a long time ago, no apprentices will ever touch my cars What's the temp coming out of the cooler, mmmmVQs, I'll put the VQ30DET I have in my 32 one day Link to comment https://www.sau.com.au/forums/topic/435145-oil-temp-on-track/page/2/#findComment-7117543 Share on other sites More sharing options...
scotty nm35 Posted November 21, 2013 Share Posted November 21, 2013 Haha yeah me to, a lesson I learnt a long time ago, no apprentices will ever touch my cars What's the temp coming out of the cooler, mmmmVQs, I'll put the VQ30DET I have in my 32 one day No idea what the temp coming out of the cooler is, perhaps I should swap the hoses around next track day. I am about to flush the coolant with Evans and see how that goes, waterless coolants have always intrigued me so I finally put some money down for it, to stop the common VQ flash boiling issue around the bore. Hopefully this will help keep coolant temps more stable. Any reason I can't run 150 degree coolant and oil on track do you think? As long at the coolant won't boil and the good synthetic oil won't lose it's properties... I can't see an issue with it. We both saw the Perth 32 gtst dyno graph with a stock VQ30det/to4z didn't we? (first page of the dyno thread) It went for a year at 24psi before lifting the head, at 430kw. All it needed was the gasket replaced and ARP head studs. Link to comment https://www.sau.com.au/forums/topic/435145-oil-temp-on-track/page/2/#findComment-7117813 Share on other sites More sharing options...
megzz Posted December 16, 2013 Share Posted December 16, 2013 I'm surprised there was only 1 mention of Motul in this thread. Thought it was the RB owners favourite?! Link to comment https://www.sau.com.au/forums/topic/435145-oil-temp-on-track/page/2/#findComment-7145085 Share on other sites More sharing options...
fatz Posted December 16, 2013 Share Posted December 16, 2013 it could be... try taking it out and see how it goes Thermostat was apples New oils filter fixed it Link to comment https://www.sau.com.au/forums/topic/435145-oil-temp-on-track/page/2/#findComment-7145090 Share on other sites More sharing options...
dan.1337 Posted January 3, 2014 Share Posted January 3, 2014 Has anyone considered running an intercooler water spray for their oil cooler to get temps further down? Maybe even an intercooler water spray that has a split barb to spray both the intercooler and oil cooler Was thinking along the lines of this as it uses the existing wiper fluid bottle and off the shelf parts: http://www.autospeed.com/cms/A_2720/article.html Link to comment https://www.sau.com.au/forums/topic/435145-oil-temp-on-track/page/2/#findComment-7159006 Share on other sites More sharing options...
intercpt Posted January 3, 2014 Share Posted January 3, 2014 Interesting idea! Would be worth trying at the very least. At 130+ degrees i doubt it will make a huge difference though. Link to comment https://www.sau.com.au/forums/topic/435145-oil-temp-on-track/page/2/#findComment-7159170 Share on other sites More sharing options...
Dale FZ1 Posted January 3, 2014 Share Posted January 3, 2014 Bandaid fix. Water spray would run out very quickly. Spend the money in the right area, namely the biggest oil cooler you can fit and decent ducting that forces air through the core. Sandwiching the oil cooler between intercooler and radiator won't do the job. Link to comment https://www.sau.com.au/forums/topic/435145-oil-temp-on-track/page/2/#findComment-7159873 Share on other sites More sharing options...
LANDSCRIBBLE Posted January 7, 2014 Share Posted January 7, 2014 I used nulon 10W60 at barbagello a couple times, after 4 fast laps i was seeing 115 degrees oil and water temp with a chinese 19 row oil cooler, filter relocator and a 52mm chinese aluminium radiator , 250rwkw rb25. I dont get how people use a 5w40 or 10w40 for 20-30 minute stints on the track. I thought they would turn into a watery consistency after 110-120 degrees? Link to comment https://www.sau.com.au/forums/topic/435145-oil-temp-on-track/page/2/#findComment-7162630 Share on other sites More sharing options...
