Camber Arms , Wheel Fitment R32 Gtst
Hi Everyone,
Thought I would see what the masses thought before we came up with a plan of attack / started spending money.
Recently we put some new wheels onto an R32 GTST 18X9 on the front, 18X10 (with 255’s) on the rear based on a couple of recommendations and it turns out that it was slightly too aggressive and didn’t quite fit on the rears.
We managed to get the guards rolled out an extra 10mm, wound the suspension stiffness up and managed to get home but I would still not be confident with any big knocks.
What I was wondering if installing rear camber arms would be a good solution to our problem? We can probably raise the rear end slightly as well which should help a little bit so if camber will sort this out are there any reccomendations on camber arms? Currently been looking at Cartel and GKTech. Other option is to flare the guards which I’m not too keen to consider at this stage.
Cheers!
Sounds like a pain in the butt. :wacko:
First thing I'd be looking at .................. if I was going down the camber path to address the problem is, how much space do you have on the rears between inner wall & damper strut? Will it be enough to give required comfort clearance between outer rear tyre wall & rolled guard, while retaining happy strut clearance? Also, while camber may solve clearance issues it often causes premature tyre wear. If camber is a viable option (acceptable negative camber vs wear rate) then you could look at adjustable bushes from Whiteline (+/- 0.5 deg) as maybe cheapest option. Alternatively Cusco or Ikeya-Formula for more camber if Whiteline not enough.
Second thing is (shudder) think about going to narrower tyre profile/wheel package. This could in reality be cheapest option in the long run.
My 2c.
Cheers GW
Hi 260tech, thanks for the input.
The car is primarily only for the track and does get some road use (about 50/50). The only reason new rims were needed was due to a crack in one of them and I think the rims recommended by the store were wider so that’s what we ordered and have hit this problem.
As the car was primarily for track use I thought a degree or so of camber wouldn’t be a bad thing so was open to this idea. I’ll have to check how much clearance is under there and get back to you about that one. I am hoping there is enough clearance and that raising the rear slightly along with a little bit of camber might be the ticket but as you said I need to check the clearance and I’ll get back to you on that one. Any recommendations on acceptable camber levels?
I wish I could just fork out for new rear wheels and have already used the opportunity to get some rims which suited the car so selling and rebuying a smaller width might be tough and will definitely be a last resort.
Thanks again
Sorry about the threads. Somehow created two when i was starting it and couldn't seem to delete one of them so that's my fault.
Definitely don't want to go down the hellastance route so it's sounding like there are two options:
1) 9" rims - definitely will be a lot more cautious about recommendations from the shop going forward - will cost approx about a grand to get in some matching rims and look at selling the current 10" wheels.
2) Widen the guards - what are the options here? Bolt on flares? pulling the guards?
Cheers
Cheers #niZmO_Man. What does buying new guards involve? Would that be something along the lines of finding GTR rear guards, installing them and then going through paint issues etc? Seems like a lot of effort for incorrectly sized wheels?
Apologies that this has turned from a camber arms discussion into a Wheels and Body discussion for those thinking that this might now be in the wrong section....
10 +20 will fit a gtst depending on what size wheel you do want to run. Will also need a bit of a massage to the factory guards. 235/40 will go on without too much hassle
Get your hellaflushstance crap out of here :P
OP, not sure on the guards as I've never done it, but I think you can buy wider fibreglass guards and get them fitted (so I assume they will cut the standard guards to make more room). Ask yourself, do you really want to run 10" wide wheels and 265-285 wide tyres? You can easily fit 9" wide on the back and run 245-255 wide tyres.
Yuh, but given that a 235 fits correctly on an 8" wheel......why the hell would you stretch it onto a 10?
Currently it is a 255 on the 10" which is currently sitting on the rears. It has 225's on the 9 at the front but was hoping to be running 235's (F) and 255's ®
 Share
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
