Hi all, 7 years ago i imported an 89 gtr through prestige. Long story, but when it arrived the motor was stuffed(big cams my ass, more like busted piston) hence didnt get complied.
The car has import approval through the old scheme. Car has an hks single turbo.
Anyway im looking at refitting an rb26(has a 30/26 now) but hopefully retaining the single setup.
After speaking to a few raws workshops im getting some conflicting advice.
am i better off getting new import approval under the new scheme, or persevering with the old scheme?
Car also has a brake conversion, am i better off putting stocker on to get it complied?
Thanks
You need to find out a few things and think about a few others:
1. Can you even get it complied now? You need to check that the old scheme is still useable for the GTR. If it isnt you would be under the new scheme - if the car complies. It may not be ok under either category.
2. You need to figure out what you need to spend to get the car registered (If it can be)
3. You need to think about what it will be worth once it is registered.
4. You need to think about whether all that is worth the hassle or whether you would be better off just buying a newer, better car and wrecking the 89.
I am so glad that 15 year loop hole was closed down. What the brokers were up to then was pretty ordinary.
I agree with all the above, it is a really tidy car, if i can get it on the road for 7k or so, then financially i think im better off. I was told that as i have import approval, i should be able to get it under raws, just have to pay again.
For RAWS it will have to be taken back to stock. 89 was less constricted. Go under the old scheme if possible.
  • Like 1
Interestingly, the old scheme is still actually open, they just changed the date backwards to 1988.
I am not an expert but I believe that since you have import approval for it, you should just be able to register it with a blue slip etc.
The other one we imported at the same time needed compliance, mine doesnt have an aus vin/compliance plate
and how stock is stock, or is it more a case of importers getting cosy with compliance shops who dont notice exhaust, wheels and turbos?
Edited by Adriano
interesting, maybe the approval was not the old SEVS, not 15 year old. Because the whole point about the 15 year / Pre 88 rule, is that the car does not have to meet ADRs or be complied.
I am not sure you will be able to switch it over to REVS compliance if that is not how it was imported either.
Hi mate, just to confirm, by the old scheme are you referring to the previous 15 year old rule or the old compliance scheme?
Yeah, i was told i would have to reapply for import approval under raws
I think the 15year rule, i had to store it in japan for a month as it was a little too new when i bought it
anyway spoke to the rms and all i need is a vsccs certificate(adr compliance test) which is $880 and a blue slip.
As far as the mods go, the engineer said they dont effect the vsccs,, but his paperwork would still say rb30, and the turbo/brakes wouldnt be engineered, i guess it comes down to whether i can get a blue slip with the motor and turbo
  • Like 1
Just to add more info -
If your car has import approval under the old 15 year old rule (where 1989 onwards vehicles were allowed) you don’t need to go through any process which requires a “Compliance” plate. You need to get your car engineered as per how you would have previously done it when it was freshly imported. For an ’89 GTR it means, side intrusion bars, fuel filler restrictor, child restraints anchors etc etc
You should already have your import approval certificate so no need to reapply for another one under the new scheme. You need to get your car engineered then follow the next relevant step as per whatever state you’re in. Not familiar with how NSW does it, in VIC it would be a road worthy certificate – you get the idea.
As far as having a big single etc, personally I think you’re pushing it a bit as chances are low you’ll get an engineer to put his/her name against that approval sign off for a car that was imported 7 years ago.
Hope that helps. I know all this as I’m in a similar situation so checked all this first before getting my ’89 GTR rebuilt and road reg.
Oh hah you beat me to it :)
Yeah that's the old 15 year rule and that's all you need. I'm getting my one done in a few months too after a body restoration. No crazy turbo upgrades so should be a bit easier.
Good luck, mate.
  • 5 months later...
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
