So here's the deal guys.
I've got oil spraying out of my dipstick tube as well as pushing my dipstick out of the tube about 150mm each time.
so clearly im getting pressure in the crank case
but ive tried all i can think of now im out of options, so far ive:
-replaced the PCV valve with a new genuine unit from nissan.
-checked all breather hoses to make sure they weren't blocked.
-done a compression test to make sure i wasn't getting excessive blow by that was causing oil to spray out. (read 140psi across all cylinders)
now thats where ive hit a wall..... i cant think of anything else to check =\
any ideas?
appreciate any help...thanks.
https://www.sau.com.au/forums/topic/435182-oil-spraying-out-of-dipstick/
just went and checked the rubber is pretty hard around the seal but its still fitting pretty firm
surely though that shouldnt justify oil spraying out of the tube right??
well damn i hope thats not the case.......
im not getting any smoke blowing out the exhaust so thats not looking likely in my case but i might still look into that if i cant get it sorted otherwise
Doing a comp test is all good & well for an N/A application, BUT, what's to say your rings are not responding when boost pressure is applied? The only way to truly cancel out your rings would be to do a cylinder leak down test.
I build, run & tune LARGE turbocharged stationary engines. I've encountered this issue before. Customer complained about an oil leak. Discovered to my surprise when going from idle to load @ about +10''Hg (max is 30Hg/14.7psi)) crankcase pressure was going from -.5'' H2O to +25'' H2O & popping both dipsticks along with twin fountains of oil till the rings responded at about +15''Hg then everything would settle down. This particular engine had issues rejecting heat through its heat exchangers, its dump radiators were too small & subsequently had alot of high jacket water temp shutdowns.
Piston rings hate heating up & cooling down. if the temps are high enough, over time, they start to lose their tension & don't respond very well to pressure changes.
Pressurizing your crankcase to the point of popping the dipstick out can only come from one place. The only other thing I can suggest as 'for the time being' fix is to get a little bit of heat shrink (for wiring), place it over the rubber, heat it & refit your dipstick to stop it popping out. Then just hope you don't start blowing out other seals!
I was just going to suggest a leak down test. :yes:
140psi compression test result isn't brilliant, especially if that was after cranking for a while. Do you have a catch can fitted?
I got similar problem whereby if I park my car on a hill it burns oil out the tail pipe...
Valve stem seals?
some really good info there thanks man
probably an easy fix there with a bit of heat shrink, but im not looking for a cheap fix here id rather get it sorted properly
and like you said id likely start popping seals lol....read up on another forum some guy just clamped the tube with a pair of vice grips :mellow:
looks like i should defiantly go ahead with a leak down test then and see how shes looking
Valve stem seals?
nah mate no catch can....... would be curious to see if im getting anything blowing out through the breathers as well as the dipstick now that you mention it
defiantly worth doing then if you think it will help
being that the breathers run back to the intake though wouldn't that cause a vacuum in the lines from the pcv valve and through the breathers though??
hence its at negative pressure anyways?.... thats just a guess
haha well lets just say
I've got a heavier foot than brian o'connor.... pretty hard
Antz. U thinking a vented can?
yup..would have to be...you could just stick little filters a top your cam cover vents , but this will most likely spray oil everywhere...
anyway, to keep it simple.. if can is vented, block pcv...if can plumbed back to intake, retain pcv...
i could tell you not to drive it so hard but you would probably laugh at me :P
If u need bud I can make u a vented can. But me thinks ur problem will be increased buy the -5s u just bought. Enjoy.
haha i know right.... thats why im tying to nut this out before i chuck em on
shit timing how it kinda came up the day i paid for them :glare: ...... lol
you do some fabrication work do you?
i actually do think i "might" have a catch can off my old 33 in the garage somewhere
ill have to have a look ....but otherwise ill get back to you about that one :)
A catch can won't really help, you'll only be increasing the size of your crankcase a little. If a leakdown test fails to show where the problem is, then testing on a dyno to actually measure the crankcase pressure is what will be needed.
In my previous post I mentioned a water column measurement: +25" H2O. This is only about 1 PSI. It was an 18 litre 6 cylinder. It didn't take much pressure to lift the dipsticks. Just letting you know even a little pressure loss can do big things.
When you do a leakdown test, try to test in KPA not PSI.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
